Hey Guys,
I'm giving my VN some TLC, and preparing it for a re-spray.
I need to remove the drivers door handle, because some punk had a go prying it out with a screwdriver.
I've taken off the inner door trim. Do i need a Torx/Security screwdriver to remove the latch mechanism, and then disconnect the rod, and pry the handle out?
Any suggestions would be appreciated.
I noticed a little switch that sits next to the key barrel - when the barrel is turned, it hits the switch and activates the central locking - i reckon the guy who tried to jack my car knew this, was smacking the screwdriver in there trying to knock the switch and cause all the doors to unlock.
um u dont need to take off the latch, pull the lil sliding pin to the side from behind the door handle and the handle falls apart and easy to then remove.
Oh. You make it sound e-a-s-y!
I shall try to take a photo tonight, cause im not 100% about what pin to pull. There is a thin flat piece of metal which sorta looks like a pin. I presume you would pull this towards the left (front of the car), when working on the drivers door?
that's the one, slide away from the door handle
Oh that was easy, a bit of light helped too.
