Results 1 to 10 of 10
Thread: Knock Sensor Circuit
    VS V6 Exec
    Feb 2007
    Auckland, NZ
    Default Knock Sensor Circuit
    I have just done the engine diagonos thing and in the two series of flashes the first had 4 and the second had 3 which means the code is 43
    I matched this and the problem was
    Code 43 - Knock Sensor Circuit
    I am just wondering if this is a problem and how it can be fixed
    Thanks, Jonathan
    Doctor Bob's Avatar
    Doctor Bob is offline Grandpa
    VT V6 Exec & VN V6 Exec
    May 2004
    Mornington Peninsula
    VS V6 Exec
    Feb 2007
    Auckland, NZ
    Doctor Bob's Avatar
    May 2004
    check the wire from the knock sensor to the ECM for continuity, if thats ok & the knock sensor is ok & torqued correctly the ECM is faulty.
    Rob
    VS V6 Exec
    Feb 2007
    Auckland, NZ
    Doctor Bob's Avatar
    May 2004
    No offence but take it to a dealer or someone who knows what theyre doing.
    VN Commodore
    Feb 2006
    Quote Originally Posted by Doctor Bob View Post
    Rob
    i didn't realised they had to be torqued properly.. i replaced mine a month ago and just did it till it was farely firm. there isn't any drama's that can happen if it is screwed in too much or not enough is there....
    Doctor Bob's Avatar
    May 2004
    Quote Originally Posted by defa View Post
    if they are too tight they will be too sensitive & react to any small noise in the engine, too loose & they will be no use at all.
    ALL threaded items on cars have a torque, & its there for a reason, sometimes to ensure the part its holding on doesnt fall off & sometimes for correct operation
    Rob
    vp exec
    Dec 2006
    vaucluse, sydney
    From the book of words.....
    1) the resistance of the knock sensor (sensor terminal to earth) should be 3000 to 5000 ohms.
    2) if the sensor resistance is ok, check the voltage at the harness (should be 4 to 6v) - i guess with the ignition on (but the book does not specify). If it is not in this range, check the wiring (white/red) back to b11 of the ECU. if the voltage is between 4 to 6v, check the wiring for chafing due to engine vibration.
    3) if no faults are found, renew the ECU.
    the book says to tighten the sensor to the correct torque... but i am blowed if i can find where it says what the correct torque is.....
    Notes:
    1. dont drop or knock the sensor. it is easily damaged... and expensive.
    2. to remove the wire from the sensor, squeeze the wide sides of the connector.
    cheers peter.
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    Knock sensor torque is 16 to 21 nm.
  1. HSV Knock Sensor in VN
    By griffindore in forum V8 Development and Modification
    Last Post: 23-11-2011, 12:02 PM
  2. Knock sensor....
    By HoZy in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 31-03-2007, 06:32 PM
  3. knock sensor
    By slyone in forum V6 Development And Modification
    Last Post: 31-12-2005, 04:48 PM
  4. BT1 Knock sensor
    By goob in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-06-2005, 11:29 AM
  5. 5L Knock Sensor
    By v8maniac in forum Electrical Wiring / Questions
    Last Post: 28-04-2004, 05:48 PM
