Results 1 to 8 of 8
Thread: Grrr Can some one please help
    VN V6 And XA 351
    Aug 2005
    Warwick QLD
    Default Grrr Limp Mode
    hi guys,
    Well my VN (v6) started playing this morning when i got it out of the shed,
    My engine light stays on and the thermo fan is running the car is runing **** house, i think i have a computer problem, its resting as i type. but can anyone help me with what is wrong??
    Jay
    cruzncommo is offline Banned
    VP 5spd
    Nov 2006
    QLD
    VN V6 And XA 351
    Aug 2005
    Warwick QLD
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    lol, that means its in "limp home" mode.
    pull the ecu out, make sure the memcals plugged in properly(take the end cover off it and the memcals the big blue one, push down hard on both ends to be sure its in right)
    then give the plugs and sockets a bit of a blow out, plug it back in, make sure its plugged in right also, start car, see if that fixes it, if not, time to startuchecking fuses and such aswell, if all fuses are good, check wiring and maybe try another ecu if you can get one cheap from the wreckers or anther car.
    VN V6 And XA 351
    Aug 2005
    Warwick QLD
    well did all of that apart from another ecu, car started ran ok the about 2min later went back to limp mode, anymore ideas???
    hakhawk's Avatar
    Jan 2005
    maybe a crook sensor.
    id get another ecu if you can aswell, try that.
    also, can you turn the car on, but not start it, will it stay in normal mode? not switch to limp home after 2 minutes?
    if so, you can check for errors logged and hopefully narrow down the problem
    holden007 is offline VRII
    Subaru Liberty
    Dec 2003
    VN V6 And XA 351
    Aug 2005
    Warwick QLD
    new ECU did the trick
  1. fuel pump not going --grrr argh
    By lord_davros in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-04-2007, 01:26 PM
