Im stuck with an allan key bolt...the whore wont budge! I whacked the crap out of it with a hammer and bent the allan key and the bolt still wont move.
Other than WD-40 what else can I do???
Where is it? Vice Grips? Vice grips on the thread?
If its in the plenum chamber, it has corroded in. You need to get an impact driver to crack the corrosion. This happens when you have a steel bolt going through aluminium, moisture gets in there and the corroded alloy expands, locking the bolt.
what about a better Allen key and a a small bit of pipe instead of the hammer.
Its between bonnet and windscreen, under plastic firewall cover. It sits between the high and low pressure air conditioner pipes.
Looks like its an impact driver job... wish I had one lol
I just gave it a go with my other allan keys, Sidchrome ones... Snapped it. So now im out of 7/32 allan keys![]()
get a touque bit to fit the bolt - hold with shifter while tapping the top of the t/bit. Increase pressure as you tap.
and 3 Dangerous non ABS VN's
I have a torque bit in it now, but its still not budging.
I might take the bonnet off and drill it out if I cant get it.
Soak it in WD40 or similar over night.
just drill it out and re tap the thread![]()
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
I ended up using the sidchrome peice in a battery operated drill which did nothing, then got it with an electric drill I borrowed at 7:30 tonight. Got the HVAC box out straight after along with all they coolant that it leaked![]()
Aluminum corrodes anything it comes in contact with. that's why you see steel screws rust when they come in contact with aluminum. Use stainless bolts when attaching aluminum to steel.
i hate bolts that dont budge, exspecially when u dont have a air supply at home to use a air impact gun. bloody bought a 900 dollar battery one and **** doesnt she rip the bolts out
We have one at work a battery impact driver, dewatt or something. If it doesn't get the bolt out it will snapped it off no questions asked :P
Ah the dramas. Good to hear your getting stuck in mate
wtb: rockford fosgate sub rfp 3412
