hey guys jsut a qcople questions.... if i was to go and buy a standard supercharger from the wrechers which is off a buick motor, will it just bolt straight onto my engine and aprox how much power (Extra) will it give me? and if i was to do a little bit of work to the charger how much more psi can i make it output?
thanx guys
ID RATHER BE BLOWN THEN STROKED
/\ ITS MY VPcustom boot
(click it you no you want to) /\
[SIGPIC][/SIGPIC]
uhm if its the same motor if not u need to make brackets n whatnot. and you need bigger injectors, different internals and whatnot. and powerwise depends. to get more psi you put on a higher psi pulley.
you mean one of the stock superchargers off the vs? i dont think they fit. about 10-11psi is about all they give. without intercooler etc.
just save the extra money and buy a super six moter with everything intact....then u wont have to try and track down everything to make it run and u wont be going and smahing pistons to bits![]()
wrecking VL COMMODORE 5 speed
FOR SALE : supra 5 speed box suite holden v8 $800
true that/\ /\ /\ but what would u guys recoment what v6 supercharged motor?
[SIGPIC][/SIGPIC]
ok lol buick didnt release a supercharger on the LN3 or other models up
it was the L36/L67 that was supercharged (L67 = VS/VT supercharged BUICK engine)
your choices are the SC14 or the M90 really with a custom made inlet manifold
they can be taken to 10psi and make 180-200rwkw intercooled
or you can go turbo for a bit extra and make more power and it will be more drivable
if anyone still checks out this can you please help us out with vs s/c parts i bought a set of vs s/c pistons from ebay but the dood had swipped the rings pins and gugeons.i can get rings but the gugeons and pins i need and conrods if possible...i need these as soon as possible any help would be appreciated as only person ive found with em so far is barsby spares in Qld and hes asken huuuge prices.if i have to buy the pistons agiain so be it. -cheers
