Results 1 to 9 of 9
Thread: VR motor & Box in VP
    Dec 2006
    Default VR motor & Box in VP
    Hi,
    Is there any difference if I put a VR motor and Auto box into a VP? I know the auto box is a 4L60-E. Do I need to change the computer or add any other bits for it to work.
    Gazza
    VP ute
    Mar 2006
    yeah there are minor differences but the only thing you will need to do is leave the Cam sensor disconnected.
    There were running changes in the later produced VPs that received VR engines minus the Cam sensor. There is a different harmonic balancer, front cover and Crank Angle Sensor. I think the flex plate was different too but not certain on that one.
    It all still plugs up and runs the same though
    The VR has a different Alternator and it has the thermostat houseing a little different with the hose coming off the front and not the side as in the VP/N.
    It doesn't matter much though. The power steering pump is a bit different with the reseviour fitted to the radiator. If you get all that too you can fit it all up fine to your VP
    EDIT>>>
    Your VR gear box will need the VR computer and loom. It is electronic and the VN/VP is not. ie the VR computer tells it when to change gear.
    You can use the engine but the gear box will be a pain.
    Dec 2006
    OK, so what if I get the engine and gear box looms along with the computer & wire it into the car. Will that still work, I have a sparky mate who could do any alterations if need be?
    Gazza
    VP Berlina V8 wagon
    Jan 2007
    Wild West
    If you get all the wiring harnesses for the box and the engine it should work just fine. Hope your sparky is a good mate! There may be some of the wiring to the dash that's a bit different too. Shouldn't be hard to work out.
    1991 VP Berlina wag V8 5.0L
    Lowered, CAI, loud exhaust, impulse blue paint but wait! There's more (to come)...
    My car..from eugh faded green and matt black to impulse
    [SIGPIC][/SIGPIC]
    vp bt1
    Feb 2007
    hey m8. just letting you know that if you have a vp then vr engine will go straight in. the only thing different is the dip stick is at the front on a vr. the trans will also bolt in but the computer will have to be changed as the vr has electronic kick down and vp is cable. if you want to do the motor alone you will have to put the throttle body off your old engine on so your kick down cable will go on.
    VP ute
    Mar 2006
    The differences I posted are already bolted to the motor so provided you get the front cover with it you will be fine
    How about getting the loom and computer and engine and gearbox, just use the engine and sell the rest and put that toward getting your current gear box freshened up
    Jan 2007
    what happens what do you have to change to bolt a vr gearbox in to a vp engine
    VP ute
    Mar 2006
    nothing, it all bolts straight in. You just can't run an electronic gear box from a VR useing the computer from a VP or VN.
    Jan 2007
    can you run a vr gearbox in a vp if you use a vr computer or how else do you run a vr gearbox in a vp
  1. vg with a vt motor
    By lil_miss_vg in forum General Discussion
    Last Post: 24-05-2009, 02:17 PM
  2. will a manual box starter motor fit on a auto box motor?
    By lil_oneblue in forum VL Holden Commodore (1986 - 1988)
    Last Post: 03-09-2007, 05:17 PM
  3. L36 GM motor?
    By HIROLLA in forum V6 Development And Modification
    Last Post: 17-04-2007, 07:02 PM
  4. VR motor into VL
    By cruzncommo in forum VL Holden Commodore (1986 - 1988)
    Last Post: 20-01-2007, 10:32 PM
  5. l67 motor
    By kyl'svs in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 02-10-2006, 10:07 AM
