Results 1 to 5 of 5
Thread: I want to put this in
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Default I want to put this in
    It's a VQ rear seat cig lighter and will be handy to have it wired in. Any one have the wiring diag for this option.
    and 3 Dangerous non ABS VN's
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    I would just tap into the front cigarette lightr plug. The colours should be the same so shouldn't be hard to match up. If not get a test light a figure out what goes where.
    88GreenVN's Avatar
    Jun 2006
    Green n yellow earth, Dark colour with it Power.
    Whats the blue?
    NickVR's Avatar
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    Probably your headlights. When you turn your lights on it turns on a light inside the lighter. It's probably uses the yellow for earth so the blue would be a control wire for the light inside it. Earth the yellow and put power to the blue one and it should light up.
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by NickVR View Post
    Cheers, I'll have a look when the sun goes down and cools off .
