Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Att Vq/vp Irs Owners
    adam69 is offline Banned
    VT Clubby
    Oct 2004
    Default Att Vq/vp Irs Owners
    Hi,i have just fitted VR/VS rear trailing arms into my VQ so i can fit later model wheels and not have clearance problems.If you wish to do this and you have any questions,ask away.
    1992 HSV SENATOR 5000i
    Apr 2006
    N/W NSW
    VT Clubby
    Oct 2004
    With the standard VQ/VP irs off set most late model holden rims will rub on the inner guards.With this conversion you get about an extra 15mm each side outwards.I has VT ss rims and they sat on the inner guards .I tried SV6 rims and there was less than a finger between the arm and tyre and about the same on the inner guard.I now have a heap of room and no need for spacers.
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Would you possibly fo a write up that could be made sticky.
    Or you could just PM me, i have WH Grange wheels, and when i first got them, they rubbed on the inside bad. Although the rubber is gone now.....lol
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    vn ss
    Oct 2005
    yea im keen for a write up about this. was always thinking about doing this but have not seen any pics or heard much about it.
    STEALTHY™'s Avatar
    Jan 2005
    I've heard about changing the hubs to VR/VS ones, but never anything about the trailing arms.
    cheers sexy
    VT Clubby
    Oct 2004
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    STEALTHY™'s Avatar
    Jan 2005
    I rekon it should just be posted in this section, as its really only applicable to people with VPs. A Sticky in here would be best.
    Once you write it up, PM a mod with the link, and they can make it a sticky
    cheers sexy
    Apr 2006
    N/W NSW
    Is my HSV "level ride" IRS different to a standard VP with IRS? The reason I ask is that the previous owner had 255 tyres under the arse & it didnt scrub(or maybe its just the offset of the rims).
    VT Clubby
    Oct 2004
    What you will need is the rear trailing arms from either a VR/VS irs.It doesnt matter if its a 6 or 8.You will need the discs and drive shafts as well.
    I will try and cover everything
    1)jack up rear of car and put on stands.
    2)remove wheels
    3)remove drive shaft using an 8mm allen key(i got a kingchrome one that fits on a ratchet and i saves heaps of time.You will have to put the hand brake on so the shaft wont move while undoing.
    4)undo swaybar 13mm
    5)remove spring
    6)you will need to undo the metal brake line that goes from the arm to the flexible line that goes to the body(they are tight and best done with vice grips).
    7)remove the spring that holds the hand brake cable to the hand brake and remove cable.
    8)the arm should be now hanging by the two mounting pionts on the body.
    use a 19mm socket and a spanner to undo the nut and bolts.
    9)the arm should now be free to remove.
    You need to use your original calipers,flex and metal brake lines,as the fittings may be different.
    10)remove the calipers and brake lines from original arms as you will be putting them on the VR/VS arms.
    11)fit these to the new arms.
    The arms are now ready to be fitted using the same removal process in reverse.
    12)use some low strength loctite on the hi tensile bolts for the drive shafts.
    13)when you go to reconnect the hand brake cables you will find they will be too short so you will need to adjust them up near the transmission.(you will see what i mean)
    14)the brakes will now need to be bled as there will be air in the system.
    15)double check every thing is tight
    If i have got you confused PM me and i will ring you to help.
    Thankyou.
    VT Clubby
    Oct 2004
    Quote Originally Posted by broderikb View Post
    If you have the original HSV VP rims then they will have the correct offset already.
    VP Executive R-spec
    Jan 2005
    I need to do this, I will when I have the spare cash to buy a complete rear end from a lsd VR/S
    STEALTHY™'s Avatar
    Jan 2005
    I just realised my whole diff disc to disc is out of a VY, so i wont need them anyway.
    You should make a new thread, or edit your first post with all that info, and then PM a mod to make this a sticky.
    cheers sexy
  15. #15
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    ^^^ So thats y u neva had a problem fittin rims to urs.
    Im goin to have to do this lil mod wen it comes a time to get sum rims.
    ________________________________________
  16. #16
    Apr 2006
    N/W NSW
    Quote Originally Posted by adam69 View Post
    Sweet, I'll put that money towards the Harrop crank
  17. #17
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    and can you believe i want to do the same thing, but in reverse! i want dished rims and the 15mm offset of the vp arms can give me that extra bit of room i need!
    excuse my ignorance, did vn/p come with abs?
    great write up btw!
  18. #18
    92 VP Calais 3.8
    May 2006
    Gold Coast
    Only the S2 VP have ABS
    Wanna swap ars ends i want the extra gap on inside
  19. #19
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
  20. #20
    92 VP Calais 3.8
    May 2006
    Gold Coast
  21. #21
    VT Clubby
    Oct 2004
    I have my old arms and discs still if you need them.Where in Melb are you?
  22. #22
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
  23. #23
    Apr 2005
    I was told about this well over a year ago. Still haven't got the cash to do the mod....
  24. #24
    STEALTHY™'s Avatar
    Jan 2005
    Quote Originally Posted by calais_cruzin View Post
    yeah i never even thought of it, til i read the write up i have.
    Believe it or not, in 4 years its seen about 15 different sets of rims, i could never make up my mind. but i'll stick to the Granges now.
    Adam69 is your car lowered, and do you have a camber kit? cause i think thats next on my list.
    cheers sexy
  25. #25
    VT Clubby
    Oct 2004
    Quote Originally Posted by ephect View Post
    adam69, are yours abs?
    Hi,no ABS but the VS i got it out of did and worked fine.The ABS parts sre on the diff center so it doesnt matter,and you use your own brake parts.
  1. VE SS Owners
    By DragonJeff in forum VE Holden Commodore (2006 - ?)
    Last Post: 20-01-2008, 04:30 AM
  2. VT 5L owners?
    By lil_oneblue in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-10-2007, 08:43 PM
  3. Ute Owners
    By brownie82 in forum The Pub
    Last Post: 30-04-2007, 11:02 PM
  4. Ute owners
    By MarzVP in forum General
    Last Post: 23-08-2005, 05:33 PM
  5. ATT: 202 Owners
    By Torana in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 12-07-2005, 09:18 PM
