Results 1 to 5 of 5
Thread: Factory Central locking
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    Default Factory Central locking
    Recently i stripped the central locking, power mirror and power window wiring loom out of a vn/vp berlina. The berlina didn't have an alarm system in it either.
    I want to use only the central locking and power mirrors and have stripped the power window wiring out of the loom.
    I have all the door motors and power mirrors and everything but just wanted to know if the central locking module was the part that can use the factory remote or there is something else i didn't get when stripping the car.
    The whole system is working but want to find out about the remotes.
    The module I am talking about is the KIEKERT module located behind the glove box.
    Also there are 2 wires that went into the main wiring harness of the stripped car but i don't know what they went to. As I said the system is working but just want to know about the remote locking.
    Thanks in advance
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    So I take it your VN doesn't have a remote? If you want to use it with the remote from the VP, you will have to fit the BCM which receives the signal from the remote and unlocks the doors. I think this is the question you are asking. Those 2 wires are probably to do with the immobiliser in the VP.
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    Thank you for that. I might go down the path of installing an alarm/immobiliser. Would probably be easier than getting the bcm out of a VP and trying to integrate it into a VN.
    JCCC NSW Member
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by MyVPIsFasterThanYourVP View Post
    the immobilizer is the bit that the remote talks to
    If you don't have the immobilser, the central locking would still work with the remote.
  1. VR central locking
    By fiendclub63 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 25-06-2006, 10:34 PM
  2. VP Central Locking...
    By fazz1977 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-11-2005, 02:55 PM
  3. VP central locking
    By msrlfc in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 21-04-2005, 06:16 PM
  4. VP Central Locking
    By richie_cky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-04-2005, 10:06 PM
  5. can u hook up factory central locking
    By russ in forum Electrical Wiring / Questions
    Last Post: 06-08-2004, 10:22 AM
