Page 1 of 2 12 LastLast
Results 1 to 25 of 50
Thread: pleasee help!!!! my engine is goneeeeee
    VE II SV6 Sportwagon
    Sep 2005
    Default pleasee help!!!! my engine is goneeeeee
    can anyone help me out, atm i am sh*ttin myself
    drivin home 2dai my car was farting and spattering all ova tha joint, revs were flucuating and there was jak **** drive (but it only happened sumtimes)
    i duno wats wrong with it, im praying its a bloked injector or gasket.......
    any ideas wat it could b?????? plzzzzzzzzz
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    First of all do a fault code test, check all the hoses are still connected along with the ignition leads.
    Selling FG G6E Turbo and buying a N/A Supra
    Sep 2005
    i wouldnt have tha slightest clue on a fault code test,
    and i cant hear it standing under tha engine bay, but u can hear it listning at tha exhaust tip
    '95 VR S2 BT1 5 Speed, N13 Pulsar Vector
    Oct 2006
    S.A. The revenue state!
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Could be Fuel pump, Crank Angle Sensor, coils/DFI unit, The CAS is the best place to start.
    and 3 Dangerous non ABS VN's
    VY SV8 HBD---mmmm LS1
    Simon Champion! On The Volley Champion! Shootin Hoops Champion! Batting Champ Champion!
    Dec 2005
    Western Suburbs
    Dec 2005
    Western Suburbs
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    Quote Originally Posted by Joey_18 View Post
    wats CAS 88 green vn
    Crank angle sensor
    We got rep back, yaaay!
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    take ur leads off an spray some wd40/rp7 in them.... have u washed ur motor recently? gotten water in somewhere...
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    Dec 2005
    Western Suburbs
    Sep 2005
    Sep 2005
    how do u check tha CAS
    if u cant already tell i dont no much in terms of mechanics, so forgive my ignorance
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Sep 2005
    ye i duno about shuvin a paper clip in there
    were can i get tha error code **** read properly........... holden dealer or?
  15. #15
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Easy to do and its free, getting Holden to do it would be about $40 - $60 depending on what mood they are in. Click the link in the second post, there is even a pic of where to put the paper clip.
  16. #16
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by T-ROY View Post
    I use a piece of solder to check the SS and the BT1
  17. #17
    Sep 2005
    ok took it for a drive with my old man last night, and of course it didnt happen when he was there, it was after id jus pressed all tha leads on, so i thought that it was just that, but then this morning sure enough it started again!!!
  18. #18
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
  19. #19
    Sep 2005
    ye alright alright, im just not too keen about shovin a conductor into the ECM circuit
    and im also not entirley sure about how 2 read tha error codes when they flash up
  20. #20
    dmitch's Avatar
    dmitch is offline DonkeySS
    VS SS S2
    Oct 2005
    Perth W.A
    its safe nearly every1 on the forum does it.. and ive never heard of it causin damage.. but if u dont want 2 ur just gonna have 2 take it 2 holden
    Check out my ride and rate it high plz
  21. #21
    VN Calais 5L
    Dec 2006
    when it starts spluttering and whatnot, throw water over the CAS and if it stops spluttering and drives normaly, then its that. other than that i have no idea. sorry.
  22. #22
    Dec 2005
    Western Suburbs
    my car kept stallin 2day every time it idled or at low revs it wood stall me and T-roy tryd 2 get it goin i turned it on reved kept popping and spluttering then tryd put i9n in drive and stalled
    finally got it home sumhow chucked my pod and pipe back on runs fina atm
  23. #23
    Sep 2005
    lets hope this was a false alarm
    it hasnt done it since tuesdai morning, and i put a bottle of injector cleaner in 2dai (id still like 2 get new injectors instead of that **** but) so see how she goes, knock-wood it doesnt happen again
    but thanks for every1s help and suggestions, cheers
  24. #24
    Dec 2005
    Western Suburbs
    yep me 2 bought me self good bottle of injector cleaner seems 2 be running all good now i hope
  25. #25
    antycore is offline Antycore
    VN Commodore V6
    Dec 2006
    Wentworth
    Default Similar Problem
    Hey
    I am havinga similar problem on my own VN. I had just done a 500km trip, smooth as. However, the next morning it took ages to start, barely started, then ran rough as guts. Tried to take off as I thought it might work the kinks out and it stalled. It refused to start once it has stalled.
    The same thing happened the next morning.
    I have checked the leads and plugs.
    I don't have a fault, (reads 12)
    The fuel pump is noisy and has been taking a while to stop after the car was running, I thought it might be that, but I am not sure.
    Can I check the coil pack by pulling off the lead, letting it sit there while someone else turns the motor? Then if there is spark from all of the terminal it is ok?
    I had the crank sensor and DFI/coil pack all replaced about 14 months ago, costing about $480. At uni now so I really don't want to spend money if I don't have to, currently relying on my gf's littly Hundai to get me around.
    Any advice would be much appreciated.
    Rob
  1. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  2. engine light, engine cut out
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-03-2007, 12:10 AM
  3. Engine + engine bay colours?
    By traindriver in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 04-05-2006, 02:06 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. Engine stalls and engine light comes on.
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 01-03-2006, 08:01 PM
