Results 1 to 6 of 6
Thread: Brake switches
    Jan 2007
    Default Brake switches
    hello how do i get to the brake light switch in my vp because i want to put cruise control in it soon and need to put extra brake switches to deactivate it to slow down and i want to ajust my brake light switch oneday so what do i have to unscrew to get to the brake light switches. cheers
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    It's right up near the top of your brake pedal. Get on your back on the floor and look up there with a torch and you will see it. But I think you will just need to tap into the brake switch wire for cruise, no need to install a new switch.
    Jan 2007
    vp exec
    Dec 2006
    vaucluse, sydney
    i think that with the factory cruise they install a separate switch - as you said (not_an_abba_fan) at the top of the brake pedal near the brake lamp switch - for safety i think..... cheers
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I think the switch is on a slotted bracket that you can slide back and forth.
    SweetWagon's Avatar
    SweetWagon is offline booosted
    VS Berlina Wagon Supercharged & VU SS Ute
    Jan 2006
    Springwood NSW
    its easier to get to if you drop the panel under the steering wheel
  1. Switches Behind Power Window Switches
    By extremeaudiowa in forum VY Holden Commodore (2002 - 2004)
    Last Post: 11-05-2007, 10:38 AM
  2. car switches off when breaking sometimes
    By hoon1 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 02-11-2006, 10:19 AM
  3. switches
    By naf33n in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-10-2006, 05:39 PM
  4. VK headlight switches
    By palmsvk in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 21-05-2006, 02:21 PM
  5. VP Cruise Control Brake Switches
    By DUMPD_VP_CALAIS in forum Electrical Wiring / Questions
    Last Post: 05-02-2005, 03:06 PM
