Results 1 to 19 of 19
Thread: Vp Help
    Cobez's Avatar
    Cobez is offline LS-EXUAL
    2004 S2 VY SS Ute
    Feb 2007
    Default Vp Help
    hey guys i have a couple of questions for you and instead to making a few different threads ill save net space and make it just one
    A) How the hell do you remove the glovebox lid on a VP? its got me farked!!!
    B) i took my centre console out the other night to spray a few lil bits on it and managed to get back in with everything working etc BUT there is a few mm gap between the top of the console and the bottom of the radio facia.....did anyone else have this problem and is it a biatch to get back in 100%?
    C) i plan on putting a custom cold air induction system in my car using PVC plumbing pipe and drilling a hole under where the original airbox sits as there is nothing underneath that behind the vacuum canister just empty wheel arch and i am going to run the piping down to the hole in the front of my senator front bar.....and also making a box to go around the pod filter to sheild the filter from engine heat......has anyone else done this and if so how well did it work?
    thanks guys
    Morton's Avatar
    Fairstar the Funship
    May 2006
    A) there's a small black plastic cylinder (about as thick as a small texta, and an inch long) that has a triangular face on it. You have to wedge this out from INSIDE the glovebox, using a flathead screwdriver. It's down the back RIGHT of the glovebox. Where it pivots. You'll find it. It's usually a pain to get out.
    Then the left hand side should just slide out with a bit of squeezing
    B) My radio facia never went back in 100% the same... It should be possible with some buggering around though. Just keep fiddling and shoving things
    C) That would work REALLY well if it wasn't a major defect... I don't think you can drill a hole in your chasis at that point without raising major issues. Someone correct me on this?
    The 1972 HQ Kingswood
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    thanks mate!!
    nah you cant if cops see it then there will be a big yellow sticker across the windscreen..........i know you guys dont condone this either!!! it is quite illegal..........and yes i do know that little cylinder you mean ill go pop the little bastard out now..............yeah i tried kicking my centre console but that didnt work so i had no ideas left hahahaha
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Quote Originally Posted by Morton View Post
    The VS has a hole through that part if the guard anyway for the washer bottle filler spout, so I would have thought a couple of holes through the bottom of the airbox wouldn't be that big a deal. Also it's not the chassis and it has no real structure.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    yeah but VP's dont so i would assume that if the hole aint there dont cut one (in law).....if they came out with one its fine but if it aint there u cant put one there legally.........thats what i thought
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    oh and i didnt mean through the airbox........there is no airbox there atm.......
    i meant cut a hole with a holesaw through the actual body under where the airbox would normally sit
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Thats what I meant too. But leave the airbox there and just run the pipe through it. Want people can't see won't hurt you.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    but then the air wont hit the pod properley.........besides im making a box from cardboard and fibreglass that will cover that section where the airbox would be to sheild the pod from engine heat so it can suck in that sweeet sweeet cold air..........
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I thought you were going to put the pod under the guard so it suck cool air from the front of the car. Then you could run all the plumbing through the air box and it would look like it was still there.
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    nope.........run piping to the hole in the guard so the air goes into that section ill have closed off from the engine bay............but now u mention it your way is a good idea too!! i like i like
    VP Executive R-spec
    Jan 2005
    It's legal to modify the inner gaurds, both front and rear without a engineers certificate
    Morton's Avatar
    May 2006
    Sweet ^^ Thanks for that foamy. I stand corrected \o/
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    Quote Originally Posted by greenfoam View Post
    really? sweet as! thanks matey now i feel a whole lot more legal and better about what is going to be done to my car on sunday hehehehe
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    and we sat down next to my car last night and checked out exactly what gaps we have and the diameter between all the radiator brackets behind the front bar.........we decided to..........put the airbox back in and connect it to the air pipe to the throttle body (standard procedure) THEN, we are going to cut through the bottom panel of the air box and straight through the guard so there is a hole you can lokk through straight to the ground through the guard.........THEN we are taking some steel piping and bolting it to the radiator brackets with an elbow fitted to get it to the front bar where it will meet a scoop in the front right hole on my senator front bar........where the steel piping meets the bottom of the air box there will be a round piece of mesh so stones etc cannot get into the air box and the air box will be fitted with a K&N high flow flat panel filter..............WISH ME LUCK! (my mate who is doing it with me works for jaguar racing and they do this stuff ALL the time for the jag race cars so i doubt a holden will be a problem)
  15. #15
    2greedy is offline VP Calais (SSV)
    VP CALAIS (SSV)
    Apr 2006
    Queensland
    Quote Originally Posted by Cobez View Post
    M8 with the console there are 2 tabs that have to fit into slots you'll see e'm now that ive told ya they are there lol as long as ya get them in right it should fit snug? I only noticed mine cause 1 was broke.
    Ok m8 hope this helps and fixes ya prob cheers!
  16. #16
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by 2greedy View Post
    But they never stay in, they slip down from where they originally sat Mine is doing it. Just add a screw or clip here and there
  17. #17
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    thanks 2greedy but yeah as VN2NV just said they keep slipping out it almost makes me wanna kick it real hard but thats not gonna help lol as i was told ages ago they never go back in 100% as from factory
  18. #18
    VN Calais 5L
    Dec 2006
    maybe thats why its out? LOL
    nah mine never went in the same either, bugger.
  19. #19
    Cobez's Avatar
    2004 S2 VY SS Ute
    Feb 2007
    hahahaha nah i was tempted to kick it but didnt.........yeah i was told ages ago: "man they never go back in 100% thats the way holden make em hahaha"
