I have an electric aerial from a VQ and Calais. The calais has this black relay? on it - the VQ dose not. Do I need one? What does it do? I want to fit the VQ to my car as the Calais one just goes down all the time.
Any help would be cool.
and 3 Dangerous non ABS VN's
Does the calais one go down all the time when plugged in to your car? As it could be module related..
I may be wrong, but the Calais one may also be aftermarket, would explain why it just goes down all the time as aftermarket ones do.
I have tried 2 modules and the calais aerial still went down. I was thinking I may be able to bypass the relay some how. I'm hoping the VQ aerial will fit in and work.
just for heads up guy's! I had a prob with the earial going up and down on it's own for no reason at all?
what it turned out to be was because i had the remote wire from the stereo going to a 1000 watt amp and 12 inch sub!
what had happened was the earth had become disconected from the amp which was causing the aerial to do some weird ****!
Re-connected the earth and everything went back to normal!
Just thought i would let you's know that in case ya have the same prob!
CHEERS!
The more I look at it mate, the more I think the calais aerial is an aftermarket one. The VQ one should fit perfect.
Can only hope it does. I'll try the VQ one over the weekend.
