hey guys i am out in my garage and i pulled the kick panel off to access the computer but can only find one screw holding it in place to the wall........where are the other ones i wanna put my old chip back in help!!
from memory there is only one screw - at the top, then its just held in by two "arms" either side which you pull it out from. at least thats how i remember it being, lol...so dont blame me if im wrong.
also have you got the special screw driver to get the screws off the plate of the ecu for access to the memcal?
Quagmire: My fellow Americans, I have not been entirely truthful with you. I did gagoogidy that girl. I gashmoygadied her gaflavity with my googus. And I am sorry.
nah i thought they were just phillips head screws?
ive only done a memcal swap in my VS, and im taking the assumption that a VP is going to be very similar if not identical - and i know on the VS i needed a weird shaped screw driver bit to get the access panel off.
ahhh ok i will have to look at that today..........yeah generally they are the same.........barely any difference at all
VP has two screws holding the bracket in, you have to take the connectors off to see the other one.
Rob
ahhhh thats why i cant find it.......hahaha thanks mate!!! i am putting the factory chip back in till i get an aftermarket ECU and chip from bresciani racing fitted.......
