Page 1 of 2 12 LastLast
Results 1 to 25 of 35
Thread: Installing Cruise Control...
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Default Installing Cruise Control...
    Ok a few questions here.
    At the moment I have the following parts... Cruise Control Switch Block, Module and cable with bracket. Im hoping all I need now is two switches for the brake pedal?
    Now I have a Series 2 1991 model Berlina which came factory with electric windows, aerial, power mirrors. Would the wiring be there for cruise control? Apparently the plugs for switch blocks and module etc. are already there, however I have yet to look.
    Does anyone have any pics of where the module is located and where the cable runs near the throttle body? Also, anyone got a pic of the plug to the cruise module?
    I already have a wiring diagram for it, just wondering if I have to wire it all myself or if some of it should already be there?
    Wiring diagram that I found on this site:
    Attached Thumbnails Attached Thumbnails Installing Cruise Control...-000_0591.jpg
    Jan 2007
    you only got to take the instrument pannel which isnt hard and connect the wire for the speed sensor and the cruise control lights and put the dash back in after checking it first and do the brake switches and the cruise control switches and run the wires out to the engine bay and connect them to the module not sure how long it will take let me know how you go
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    I don't have any pics, but i can get some later tonight, and maybe upload them tomorrow (my comp at home is ****ed)
    The module sits under the Airbox (on its side along the inside of the strut tower) and the cable runs along there, then bends up and goes behind and then around the Aircon setup to the Accelerator cable.
    This is on a VP with cruise, so i assume the VN is the same as the V8 models are the same.
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    1991_Vn2nV's Avatar
    Mar 2006
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Here are some pics for location....
    and 3 Dangerous non ABS VN's
    STEALTHY™'s Avatar
    Jan 2005
    Lucky he had pics, cause i forgot the cord to plug the camera into the computer, and this dodgy work comp doesn't have a thing for an SD card, only a USB
    Pics are the same as my VP anyway.
    cheers sexy
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by 88GreenVN View Post
    Man I would give you rep but it wants me to spread it around before I can give it to you again Thanks heaps for the pics
    88GreenVN's Avatar
    Jun 2006
    Hey Note my Factory Cold Air Intake on the Wagon!!
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    I was about to start this exact same thread.......
    Anyway, brake switches? How do you fit them? And what sort of switch would be required? I was sorta thinking since the cruise loom is already in there and as the brake already has a coupla switchs on it for lights etc that it would already be set up...just a matter of hooking in switchbank and module...
    am i way off base with that?
    88GreenVN's Avatar
    Jun 2006
    Quote Originally Posted by mulligan-can View Post
    If you have 2 switches on the brake then one is most likely the cruise switch. The Cruise loom has a grey 2 pronge connector to plug onto one of them.
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Hehe, I haven't checked yet . Was just thinking as everything else is pretty much plug and play....
    Ok, say the switch isn't there where would you find another? Assuming there are none at the local wreckers and that I can't get to the nearest decent sized city to check there (seriously man, living in FNQ is lame, I'm 80km out of Cairns and work keeps me away 95% of the time that the wreckers there are open...)
    88GreenVN's Avatar
    Jun 2006
    If the loom is not in place you will need to buy a retro fit cruise control loom. Holden dealers should carry it.
    The switch - Go to the Ebay online shops, easy as.
    1991_Vn2nV's Avatar
    Mar 2006
    Speaking of this, I cant for the life of me find the plug for the cruise module yet it appears the wiring is all there at the switch block...
    Also, theres no holes to screw the module in which means I have to drill
    88GreenVN's Avatar
    Jun 2006
    I hope the plug is there! or no cruise control!
  15. #15
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    In the VN where does the cable hook onto? In that pic there appears to be a bracket? It can't mount on anywhere else right?
  16. #16
    88GreenVN's Avatar
    Jun 2006
    Yep you'll need a bracket
  17. #17
    Bent_6 is offline 3/4motorsport
    VT S1 Acclaim V6/ VS SII Acclaim V6
    Jan 2007
    Just right of the redline
    Im about to do this aswell but because my loom doesn't have the cruise module wires im going to fit an entire VP Main Wiring Harness to make it look factory fitted.
    I have run this past the Doc and am waiting for a reply as to how it will work.
    If he agrees it is the way to go, i will post up the way i did it for you to see.
    Just not sure when i will find the time to do it.
    Steve
  18. #18
    94 vr 5sp, 04 vz wagon,82 vh efi wagon,88 vn 5sp
    Nov 2003
    northside brisbane
    Heres a picture of it out of a book http://forums.justcommodores.com.au/...3&d=1127345326
    Shows the buick type engine like in a vn but its in a vr but all the install is the same
    This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain ......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
  19. #19
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    I seem to have a green wire coming off the cruise loom that ends in a little elbow sort of black plug thing. Where is it supposed to plug in? Its only about 50cm long and I cant find anything that looks right...
  20. #20
    88GreenVN's Avatar
    Jun 2006
    Could be the connector for the anti theft swith/bonnet open warning switch. Cant recall if the VN's had such a thing.
    Its mounted by the bonnet catch and there is a rubber stopper the closes the switch when the bonnet is closed properly.
  21. #21
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    Hmmm, well, I have a VN S1... and the green doodad is part of the factory loom that came without cruise... and I do not have that open bonnet warning switch.... I do however have a nice little hole where it should be...
    Haha and I also had the 4th plug for the lvl 3 dash... gosh... its appearing that my car has the Calais loom in it... is it supposed to? (perhaps that is a question for another thread...)
  22. #22
    88GreenVN's Avatar
    Jun 2006
    Some one could have put the 4th plug in. But if you have the cruise plug by the LH headlight then yes you probably have the Calis loom in your car. Have you looked for the 2 brake switches?
    Does your car have the trip computer switch blocks/electric arial?
  23. #23
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    It came with an electric aerial but not with the trip switch block, I had to pick one of them up from the wreckers, same with cruise switch block.
  24. #24
    88GreenVN's Avatar
    Jun 2006
    Just to add a pic of the brake switch.
  25. #25
    VS S Pack Ute
    Mar 2007
    Cairns, QLD
    -sigh- Guess I need to go hunting for a brake switch. Ummm, that switch has two connector doodads on it? What else can hook up to it aside from the cruise?
  1. installing cruise control
    By slappa. in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 22-10-2006, 09:22 PM
  2. installing cruise
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 10-06-2006, 05:13 PM
  3. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  4. Installing cruise control
    By Hakka in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 16-02-2006, 10:02 AM
  5. Installing Cruise Control???
    By holdensupporter2005 in forum VY Holden Commodore (2002 - 2004)
    Last Post: 10-10-2005, 11:34 PM
