Results 1 to 15 of 15
Thread: replacing steering wheel?
    sganro is offline i speak before i think
    yet another VS
    Aug 2005
    NQ
    Default replacing steering wheel?
    The steering wheel in my VN is just about buggered and needs to be replaced so it will pass roadworthy. A mate told me i will need a steering wheel puller to get it off. Is this correct?
    There are no stupid questions, just stupid people
    vn calais
    Dec 2006
    you can do it without 1. just take the horn pad off and loosen the bolt off a few turns, but leave it on. hold the wheel on ether side and lever it back and forth and it should pop off. then undo the bolt and hey presto.
    VK 5litre, GSXR600
    Jan 2007
    gladstone qld
    if it doesnt pop of like said above just put a socket over the nut and give it a gental tap while pulling it towards you. might need someone else to help
    yet another VS
    Aug 2005
    NQ
    righto cheers, i will try that
    Vt-Brrrlina is offline vp bt1 gts replica
    vp bt1 5.0ltr full GTS kit
    May 2006
    Perth, Western Aust
    dont forget to leave the nut on to start - so ya dont bash ya head in when the wheel eventually comes off - dont laugh have seen it happen - (no not to me) ha ha
    vp v6 commodore executive
    Aug 2006
    south island newzealand
    Better off getting a puller I have allways just put my knees behind the wheel and hitting the nut with a hammer but did this to my vp the other day wondered why my new $100 wheel-boss wouldnt fit had pretty much effed the collum and you dont want to know how much threads left to hold the nut on with.damage is emminent buy a puller or borrow one wish I had.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by les82 View Post
    Better be a gentle tap or you will push the steering rack down. Extremely easy to do.
    I would spend the $10 on a steering wheel puller. They are great! And will last forever
    VN S Pac VH SL/X
    Jul 2006
    get a steering wheel puller !!!!!!!!!!!!! cheap and easy. I did the hammer treatment and $250 i had a new column and rack.....just get a puller dont attempt with hammers its just not worth it
    yet another VS
    Aug 2005
    NQ
    Dont really wanna do any damage, so i might go and invest in a puller today
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    yeah go the puller, totally worth it.
    also, make sure you put the new wheel on 100% straight like the old one,
    i figured since my fronts were straight ahead that the wheel should be too, but it was just a bit out, probably pays to check before you put the bolt back on the steering wheel.
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    How to remove a steering wheel 101.
    Step 1: Remove horn pad and retaining nut.
    Step 2: Sitting in the seat, make fists with your hands.
    Step 3: Hit the wheel at 9 and 3 of a clock face hard and fast.
    Step 4: Slip wheel off and fit new wheel.
    1991_Vn2nV's Avatar
    Mar 2006
    There are many ways of removing a steering wheel, but the only one that ALWAYS works, especially straight away is a steering wheel puller.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    That is not entirely true. If someone has tried before and buggered the threads in the steering wheel, the puller won't work. I used to do wheel alignments and I have never used a puller on a steering wheel. The only reason I took the wheel off was to put it back in the correct position after someone else did it incorrectly.
    VN S Pac VH SL/X
    Jul 2006
    Quote Originally Posted by Not_An_Abba_Fan View Post
    because I used a trusty hammer to get mine of I had to buy a new rack and column....they cost alot more then a puller...i will not ever use a hammer to get a wheel off again as for the vs wheel it just pulls off after arguing with it for about 5 mins
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yeah, hammers are a no no. Good old trusty fists. Cheap, easy to get hold of and works even better when you picture your ex on the wheel.
  1. Replacing Steering Wheel Radio Controls VY SS
    By holdenjohn in forum Electrical Wiring / Questions
    Last Post: 19-12-2009, 10:28 PM
  2. Replacing steering wheel audio buttons in a VX
    By beamer in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-09-2006, 06:17 PM
  3. Replacing the Steering Wheel
    By azman in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 25-08-2006, 05:08 PM
  4. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
  5. Replacing Steering Wheel
    By jacob1986 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 24-10-2005, 04:59 PM
