i dunno wether its wiring or what but when i push the aircon switch you dont hear the compressor come on and the aircon doesnt work. trouble started with it when the switch broke (it went inside the dash ]=)
has the a/c system got gas in it?
also did you check the fuse for the ac?
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
a/c has gas and fuse is fine.
what happens is there is a pressure switch in the ac tank, when the gas runs out or leaks out all the pressure, the switch clicks and the compressor wont turn ongo get the air con regassed and shel be fine
it has been regassed :S
Did you replace the switch that broke??
hey my aircon blows hot air...lol....well its actually works for a few minutes before then dies... what d'u guys think it is :-p ???
kev
your air con can only be regassed if it works. Did it get regasses before it broke???
