Results 1 to 9 of 9
Thread: not getting fuel
    vp ss
    Mar 2005
    Default not getting fuel
    ok i have a vp auto 5 litre when ya give it some around corners it dies then when ya straighten up it starts to run again it only seems to do it when i have under a half a tank of fuel,dont know if its my fuel pump or the float or something,anyone have any ideas what it could be.its only does it when ya give some around corners and go round a bend to quick.
    cheers gav
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    drive like a granny no, check at the fuel tank where the fitting are and make sure everything is secure there
    Body by Holden, Soul by Brock
    the Legend will live forever
    vp ss
    Mar 2005
    xcop5l's Avatar
    xcop5l is offline 4th year spanner spinner
    VN ex cop 5L
    Jun 2006
    ol' geelong vic
    pull out your fuel pump and have a look inside the tank with a torch (not a lighter hahahahahah) take note of where the lowest part of the pump is and then have a look at the baffel box. its a rectuangular box with no top on it inside the tank that the fuel pump sits in, if the fuel pump isint sitting in this box or the box is broken this will be your problem. if the box is broken you will need to get another fuel tank as you cant change the boxes over
    Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
    MY RIDES
    [SIGPIC][/SIGPIC]
    http://forums.justcommodores.com.au/...ad.php?t=41837
    vp ss
    Mar 2005
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    definety float, my mate had it in his vn couldn't drive under half or it'd just die
    We got rep back, yaaay!
    vp ss
    Mar 2005
    cheers mate.im gonna give thumbs up to this forum been really helpful.this would have to be the best car forum ever.cheers guys.
    Apr 2006
    Auckland NZ
    good to have a happy customer
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Hey i have the same problem my car has been doing it for the last year and i dont no what it is i have replaced. fuel pump/Sender twice/ the fuel filter and the fuel tank and it still does it i took it to a machanic he said its loosing fuel pressure and they checked pump and line and i ran out of money so they didnt check the fuel tank but i replaced it anyway cause it had some dents in it. i was thinking maybe the regulator or a loose wire thats what other people say. i am going to replace my motor with a VR one cause i did a crank shaft rear bearing and i will see if its the motor.i will write back and tell ya. good luck.
  1. fuel surge turning right? weird inst fuel readings
    By vkotis in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 18-10-2006, 12:00 PM
  2. leaking fuel damper and fuel pump adventures
    By harry3 in forum VL Holden Commodore (1986 - 1988)
    Last Post: 18-08-2006, 04:00 PM
  3. fuel injected 5ltr motor setup for dual fuel
    By ma77es in forum Swap / Wanted to Buy / Trade
    Last Post: 28-05-2006, 07:03 PM
  4. VS Internal fuel pump issue (duel fuel)!!!
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-09-2005, 08:10 PM
  5. Steel Fuel Line Into Fuel Rail Question
    By VTSSDUDE in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 27-09-2005, 09:50 PM
