Hi, I have just converted my level 1 dash in my VP series 2 Sedan, to the Level 3 Calais dash.
Everything works fine, other than I cant reset the LCD with fuel usage, and trip time. Nothing happens???
Anyone know whats going on?
you have to hold mode and reset or something, it's a 2 button combo.
ok cool, ill try that in the morning. Earlier i tried +and- together, and the displays stuffed up. ill try mode and reset tomorrow.
this might help
level 3 dash, who knows how to work it?
cheers for that, pressing reset and mode together did the trick! Haha
Thanks![]()
Also, im wondering if you know how the over speed warning system works. Like how do you set it ect. Im guessing that there may be some module neede, (which I dont have)?
to turn it on and off you have to press reset a couple of times (maybe even 3) when it's in that mode.
to set it press the the + or - button, i think after the battery is unplugged or whatever it reverts to 200k, and the - button takes it down by 5 k each time.
it should beep and show the "spd" warning light when you go over, but won't continue to beep. only continue to show the light.
