Results 1 to 12 of 12
Thread: Window Wiper Wash Button thing : /
    91 Exec
    Jan 2007
    Kingsley, Perth
    Default Window Wiper Wash Button thing : /
    Hi,
    Im not sure what to call it, but on the knob where you turn your window wipers on and stuff, there is that button you push to squirt the water.
    The water tank is full, but when I push it no water comes out, just the wipers go... is there a motor for this that could be broken or???
    Thanks heaps.
    Stephen
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    yeh there is a motor on the side of the washer bottle that most likely is rusted and the fins on the bottom have snapped off so it pumps no water.... they arent very expensive to replace
    VN Wagon
    Feb 2005
    Listen for the washer motor.
    Unplug the hose to the nozzles and then press the button. Is there a good stream of water? If not then looks like the washer motor.
    If there is water then check your nozzles for a blockage.
    MasterOfReality's Avatar
    MasterOfReality is offline Thats Dr to you.....
    VP HSV Enhanced Calais, 2006 Suzuki Grand Vitara
    Feb 2004
    Where the mines are
    I had exactly the same problem!
    Most likely its the button in the left hand side switch bank that has buggered up.
    Pull off the lhs switch bank and have a look and you will see that when you press the button, a tiny rod comes out to make contact with a metal strip. The metal strip gets pushed down onto something else which then sets the washer off. Its hard to explain cos i cant remember the exact details.
    What would have happened is that the metal strip will have been pressed further down over time, until the rod can't make contact with it.
    All you need to do is fold up a bit of paper or cardboard and jam in behind the metal strip, so that it gets pressed down when the rod pushes on it.
    Only took 30 minutes, and better than spending heaps on a new switchbank.
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by MasterOfReality View Post
    He said the wipers are still going so its not the switch.
    Selling FG G6E Turbo and buying a N/A Supra
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    But when you push the button doesn't it rotate the arm turning the wipers on? The contact for the washers could still be stuffed. But I would check the motor on the bottle 1st as this is more common.
    May 2004
    Quote Originally Posted by Not_An_Abba_Fan View Post
    No it doesn't rotate the arm. It is just a contact.
    99% certain, the issue is with the washer bottle motor or connector.
    91 Exec
    Jan 2007
    Kingsley, Perth
    thx for your replies, should be most helpful. been busy with work so ill have a look tomorrow.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    Yep, what most people have said here.... i had the same problem and it turned out that the little motor was all dead and rusted like a bitch. got a new one.. stuck it in then re adjusted my nozzles and PERFECT! ....
    Morton's Avatar
    Fairstar the Funship
    May 2006
    I'll second (or third) that. I had a similar issue... popped down to my wreckers, got another washer motor out for five bucks, and she works again
    The 1972 HQ Kingswood
    vp exec
    Dec 2006
    vaucluse, sydney
    its pretty straighforward:
    1. test the washer motor..... put a multimeter across it and measure the motors resistance. any meter deflection means the motor is probably good.
    2. press thre wash button & look for 12v (with a light or meter). yes = power feed, switch and wiring loom all good. If no, see step 3.
    If yes to steps 1 and 2, and it still dont work, the problem is probably mechanical in the motor and replace it. i think its sealed.
    3. Remove the switch block. There are 2 exposed contacts in there that are hit by a rod and join when the button is pressed. On mine, i had to bend the outside contact a bit (at the base of the contact, with fine nose pliers if i remember correctly - carefully!) so that when the wash button is pressed, the connecting rod from the button to the contacts pushed them together.
    The "wash" button, when operated, sends power to the "wipe" circuit monetarily so that when u wash u get 1 or 2 wipes.
    Remember to raise the wiper blades off the screen thru all this - wiping a dry screen will scratch it.... cheers. pete
    Feb 2004
    Where the mines are
    Quote Originally Posted by AirStrike View Post
    Yeah, my wipers were going as well, and I also replaced the little electric pump.
    The contact in the switch is buggered.
  1. VN-VP Level 3 Cluster with Trip Computer/Wiper Button module
    By AlpineRaven in forum Parts And Other Items For Sale
    Last Post: 09-02-2007, 08:43 PM
  2. Painting window wiper arms
    By dawg in forum General
    Last Post: 06-12-2006, 05:42 PM
  3. Mode button/function thing
    By VT2VEight in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-12-2005, 04:53 PM
  4. Windscreen wiper wash button
    By vp manual wagon in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 19-09-2005, 08:21 AM
  5. Help: Window Wiper Removal
    By Infus10n in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 29-03-2005, 11:52 AM
