guys i was just wondering if your centre bearing is worn and noisy would you hear the noise right through the car? what does it sound like. does it sound like wheel bearings or diff whine? any help would be great.
it sounds like the tailshaft is going to fall out lol but thats when its totally gone
its just a loud clonk thats sounds like metal hitting metal for some reason...thats what mine sounded like anyway
im havin this prob aswell, i just got my centre bearing in the tailshaft replaced but its still kinda of there. can u explain about it being balanced? mines lowered and i havnt got a adjustable panhard rod. but i never had this problem until recent
VS SS - Street/Show Project [BEEFY]
http://forums.justcommodores.com.au/...-beefy-v2.htmlHID Kits from $100 - Installation available PM FOR DETAILS
If the bearing is gone, it would sound like a wheel bearing but it would not change when swerving left and right. If the CV joint was gone then it would be rattly at low speeds, and if it was the rubber it will vibrate.
Did you start having the problem after the centre bearing was done? If so then it may be a balance issue as the two halves have to be put back in exactly the same position.im havin this prob aswell, i just got my centre bearing in the tailshaft replaced but its still kinda of there. can u explain about it being balanced? mines lowered and i havnt got a adjustable panhard rod. but i never had this problem until recent
From factory the tailshaft is balanced as a complete unit, so when it spins it doesn't vibrate. If it has been separated without it being marked then it can be put back in about 200 different positions (the number of splines x the 6 allen bolts), this will result in a vibration if it is put back in the wrong position.
Also with it being lowered, have the spacers been removed from the centre bearing mount? Maybe this is your problem, if the spacers are still there, the two parts of the tailshaft will be at the incorrect angle causing wear on your CV joint and rear uni and this can cause a vibration too.
mine rattles at low speed and slow takeoff and vibrates while crusing along. the problem was there before the centre bearing was done, and im prety sure the spacers wouldnt have been touched so that may cause some problems.
Body by Holden, Soul by Brock
the Legend will live forever
