Results 1 to 11 of 11
Thread: too much transmission oil
    vn executives
    Sep 2005
    Default too much transmission oil
    hi, guys, what will happen if there is too much tranny oil. when should we check it. warm or cold.
    AttaBoy is offline WTF?!?!
    VS Acclaim V6
    May 2005
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    You check it at operating temp. Either go for a quick spin around the block or with the engine on and your foot on the brake go through all of the gears from park to 1st stoping at each one for a second or so, do this for around 5mins.
    Selling FG G6E Turbo and buying a N/A Supra
    vn executives
    Sep 2005
    thanks guys, I think you are right. if there is too much does it really matter or should we take it out.
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by andyli View Post
    Your best off taking it out, there's a reason they have a maximum mark on the dipstick.
    VN Calais 5.0/vy sv8/r31 rb20
    Oct 2006
    sydney
    Quote Originally Posted by AirStrike View Post
    yes this is correct, go through all the gears from park to 1 hold each for 5 sec (when u in the car and foot on brake) then back up holding each for 3 sec. you can then check oil level in park or drive. normally an auto will be fine if it over full but if you have any probs you'l have to take some out. th700's are very sensitive box's but you should be ok
    immortality's Avatar
    VN3.8 5spd/VSII3.8/VH5.0
    Apr 2006
    Auckland NZ
    too much trans fluid can lead to airration of the fluid which basically means the fluid becomes compressable and you'll loose holding power in the trans causing slippage/overheating and all sorts of other problems etc
    Body by Holden, Soul by Brock
    the Legend will live forever
    Mar 2006
    Quote Originally Posted by immortality View Post
    and if it overheats and bubbles out the dipstick tube you could start a fire on the exhaust manifolds.
    vp_5ltr is offline Sik SliDeR
    vp 5 ltr 5 speed
    Jan 2007
    yeah too much fluid causes the trans to slip like a deamond .. and also **** goes everywher elol . to test it drive the car for 5 kms and leave it in park then take the dipstick out wipe it and put it back in, pull it out again and see what it says
    vq~gangsta's Avatar
    vq~gangsta is offline Resident science geek
    VQ Statesman 5.0L
    Oct 2005
    It can't overflow from the dipstick.
    there's an overflow valve at the back of the trans. If you over fill it you just make a bloody mess all down the back of your block and trans.
    It's best to suck some oil out with a hose through the dipstick pipe.
    I'd rather push my Holden than drive a Ford
    vn executives
    Sep 2005
    thanks for all these, will suck some out and hope my VN would last for another year letting me graduate at the end of 07.
  1. WTB vr transmission
    By SthEastCustoms in forum Swap / Wanted to Buy / Trade
    Last Post: 17-04-2007, 11:33 PM
  2. Code 68 - Transmission Component Slipping - Auto Transmission Only
    By tysons_2001 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 13-12-2006, 05:14 PM
  3. transmission
    By myvq5ltr in forum General
    Last Post: 08-08-2006, 10:59 PM
  4. Transmission Oil
    By statey27 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-11-2005, 12:52 PM
  5. need transmission
    By DaveP in forum VL Holden Commodore (1986 - 1988)
    Last Post: 17-08-2004, 11:09 AM
