Hey all, the speedo in my senator always displays the wrong speed. When it says Im doing 80 im actualy doing 60 & when it says im doing 120 Im doing 100 ect ect.
It also goes through the gears very quick(4spd auto with stg2 shift kit) & runs along at 2000rpm at 80kmh in 4th.
I am unsure if it has the standard diff center, but would a taller diff ration be the reason for the speedo being out & doing 2000rpm at 80kmh?
Sounds like you had a ratio change b4 you bought it? Lift the rear end and mark the talshaft and the tyre spin the tail shaft once and get a rough ratio.Obviously, 3.08, roughly 3 tyre revolutions, 3.46 roughly 3 1/2, 3.73's, 3 3/4's?...
With the speedo off by that much it sounds like 3.91's...
How many rpm are you sitting on in overdrive at 100km/h?
about 2,200-2,300rpm.
Sounds like it has at least 3.45s in it
I would say 3.45 or 3.73... My 3.9's rev much higher at 100... But definitely sounds like a diff gear change.
Just check it your self. You'll work it out...
yep thats 3.91 mine is the same
