Results 1 to 8 of 8
Thread: coolant
    vq statesman 5ltr
    Oct 2005
    Default coolant
    hi all, whats the best type of coolant to use with a 5ltr injected vq statesman?? i heard that theres this red stuff these days?? i just want to use a holden recommended coolant..
    [SIGPIC]http://i65.photobucket.com/albums/h213/pocketlife/vq.jpg[/SIGPIC] i feel the need for speed
    car
    Jul 2006
    greensy, melb
    i just used a normal coolant from autobarn and ive never had a problem
    "A life lived in fear is a life half lived"
    dmitch's Avatar
    dmitch is offline DonkeySS
    VS SS S2
    Oct 2005
    Perth W.A
    just stick to the normal green coolant and u will b fine.. but dont get the cheap stuff
    Check out my ride and rate it high plz
    vq statesman 5ltr
    Oct 2005
    Default mixing
    whats the mixing ratio ?? ive heard that if you put the wrong coolant u will be up **** creek,
    Morton's Avatar
    Fairstar the Funship
    May 2006
    If I were you, I would just be making sure it has rust inhibitor, and contains anti-freeze and anti-boil, boiling around 134 degrees or thereabouts. I like a 50/50 mix off the bat, so I can afford to dilute the mix a little over time, but that's just me I also mix the leftover coolant with an equal amount of water, and keep that in the boot for top-ups. Almost like pre-mixed cordial
    The 1972 HQ Kingswood
    VX GTS 427, VS Calais 383 A4, VS Clubsport 185 A4
    Aug 2004
    A 50:50 mixture of coolant/water is the recommended mix. You can't go past the Holden coolant even though it might cost a little more. The cheap stuff is just coloured water.
    vq statesman 5ltr
    Oct 2005
    Default holden coolant
    oh holden coolant where can you get it, and what is it called?? thanks for the info btw
    Morton's Avatar
    May 2006
    I'd be trying a large Holden dealership like Patterson Cheney on Canterbury Rd.
  1. What coolant do you use
    By glowworm in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 30-11-2007, 06:29 AM
  2. Coolant Vn Ss
    By RVN 355 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 18-05-2006, 11:43 PM
  3. Coolant In VX GEN 3
    By 1stGEN68 in forum General
    Last Post: 03-04-2006, 12:43 PM
  4. VR coolant
    By C.V in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 07-10-2005, 09:26 AM
  5. Coolant VX
    By MoSkA in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 16-05-2005, 01:20 PM
