What needs to be disconnected for me to pull the motor? Has someone got a scanned part from a manual that could help me?
obviously if you don't want the tranny out,unbolt that,radiator hoses,heater hoses.any earth straps,battery positive lead,easiest way to disconnect all the wiring is unclip major wiring from ECU push the plastic tabs in and push/pull thru firewall.....sit wiring loom on top of motor,disconnect MAP wiring from its sensor,the on that is bolted to firewall(just unplug the wiring from that)if it has air con,just un bolt the compressor holding plate from motor and sit to the side (that way if you A/C is in good working condition,you don't have to un bolt lines and let your gas go ,etc,etc...you may have to hold your mouth right if you have big hands,to get in under the A/C compressor thats bolted right above the engine mount.....then just visually look before raising motor to make sure nothing else is attached to car from motor....thats about it...
Thanks for that![]()
From the book condensed to fit in one post.
1 Depressurise fuel system
2 Disconnect BatteryTerminals
3 Remove radiator cap loosen bottom radiator hose and drain into container . Remove top and bottom hoses and undo trans cooler lines at radiator .
4.Remove cooling fan assembly ....4 bolts and a wiring connector...could be a idea to remove radiator then so it cant be damaged
5.Drain engine oil.
6.Disconnect washer hose at l/h side of bonnet
7. With help support bonnet and remove struts at pivot on bonnet then remove hood bracket to hinge attaching bolts and remove bonnet.
8.Loosen rear heater hose clamps at engine and undo nut and release rear lifting bracket to hose securing clamp.
9.Loosen and take off the front heater hose near the steering pump.
10.Undo the wiring connectors near the fuse/relay box.
11. Remove neg terminal nut at inner guard and also take off positive feed wire at fusible link housing remove clip at fusible link bracket that supports harness.
12.Remove power steering hoses from back of power steering pump and drain oil into container.bracket to be undone on high pressure hose.
13.Take out wiring clip on intake duct at back and remove intake air duct elbow assembly by undoing large hose clamps on each end and stud to fender bracket nut.
14.Undo cruise bracket and cable if fitted and take cable off throttle body stud.Take off throttle cable also.
15.Loosen and take off fuel hoses at back of engine
16.Take off l/h kick panel and disconnect ecu connectors.
17.Undo map sensor wiring on firewall and push disconnected ecm wiring through firewall after releasing grommet and lay over engine protect in a plastic bag to stop ingress of dirt/grease etc.
18. Disconnect emission canister hoses at throttle body and unclip and lay away from engine.
19.Disconnect vacuum hoses at map sensor and throttle body.
20.Remove tailshaft from gearbox and drain gear box oil ....automatic will have to undo trans panbolts and drain into container
21.Undo each exhaust pipe at manifolds
22.Disconnect gear shift at gearbox or shifter/console inside cabin for manuals also manual cars disconnect clutch fork cable etc.
23.Disconnect wiring for transmission and oxygen sensor wiring near exhaust pipe.
24.Attach lifting hooks chains to brackets with some liting equipment(winch ,block and tackle etc)and raise engine slightly to take the weight.
25.Remove air con compressor and tie away from engine
26 Undo left and right engine mount to engine block bolts and mount to frame bolts and remove mount/bracket assemblies from engine.
27.Take out 2 steering rack to crossmember mounting bolts and take out input shaft coupling nut and bolt and pull steering rack away and clear from crossmember and let hang down on the tie rod ends.
28.Remove rear crossmember bolts and rear trans mount bolts .
28. Raise engine upwards supporting rear of gearbox so it doesnt drag on floor .
29.Raise higher giving attention to anything that might snag (Gear shifter, throttle body at firewall etc) and protecting wiring connectors ,hoses still attached to engine and remove engine /transmission assembly out of engine bay supporting rear at transmission and manovering around suspension crossmember as you go.
This is my vr that I rebuilt ....CLICK HERE to see my vr on Cardomain
......if you want to check it out......Anyway make sure you rubbish a ford daily ....I am a 4DH8RZ Club lifetime member .................new members joining everyday
LOL all that for my basic post.... good comeback
Says the same with more detail but we arent all rocket scientists like your good self
Dont do what i did once... i left the speedo cable hoked to the gearbox when i dropped the motor out...
broke the fitting and the speedo never worked afterwards (well it did slightly until i did a bit of a naughty one day and it stopped working..
Its funny to tell people you took off so fast from the lights that your speedo broke... haha.
Also watch out when disconnecting the fuel lines as this can get messy if the line is still pressurized.
Dont like my driving? Get off the sidewalk!
1988 VN Calais: CAI, 2.5inch Catback, 18x8.5shadow chrome wheels, JVC DVD player + 7inch Screen.
