Results 1 to 8 of 8
Thread: :bang:
    1990 VG ute 3.8 auto
    Mar 2007
    qld
    Default :bang:
    Thanks Everyone For There Imput Ive Fixed The Problems Ive Had With The Car And Now Selling Ti Its Good Now So Im Happy
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Mar 2007
    qld
    hakhawk's Avatar
    Jan 2005
    the surround around the gauges with the buttons on it, that all unscrews, so u pull that off(detatch plugs on back of switches), then a couple more screws and the gauge cluster comes out. then on the back of that is a heap of twist in globes.
    have a search around the vn/p section, im sure there would be a tutorial on removing it somewhere
    Mar 2007
    qld
    vs wagon
    Jan 2006
    redcliffe
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by BURK_POP View Post
    whats that lol soz im not good with the dash
    undo the 4 screws that hold the dash cluster surround on,remove it,then undo the 4 screws that hold cluster into place,gently pull it forward,manouviring around the steering column and wheel,you will see the bulb holders in back of cluster,remove them(twist to unlock them,check colour of them,if they look black....cream they are blown,if they are still clear have a close look and see if the filament is still intact,if not...it's blown(the little dash bulbs)but before you go doing that,check fuse panel using the fuse identification sticker,your fuse for illumination may be blown,i don't know off hand now what number sequence the fuse is,but it will have something like illumination and something else written next to it on the sticker as to where the fuse is located....
    PS don't touch the printed circuit board on back of cluster,accidents can happen,so it's best not to touch circuit board
    Mar 2007
    qld
    oh yeah cause my interia light fuse blew earllyer i forgot about that thanks
  1. ARRRRRH! HELP loud bang bang bang noise
    By PaRaDoX in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-02-2007, 10:58 PM
  2. re:big bang
    By VK1981 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 17-02-2006, 08:42 PM
  3. Bang :(
    By fitzy2005 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-01-2006, 06:14 PM
  4. Bang
    By PhatVN in forum Car Audio
    Last Post: 15-10-2005, 12:19 AM
  5. bang for bux
    By itchy pits in forum V6 Development And Modification
    Last Post: 03-08-2005, 05:44 PM
