hey, does anyone know when wiring up a 2 bar map sensor, do any of the wires need to be changed??, i know new slots are required to make the connector fit
this is diffrent as its for the GM ones, but it gives a idea
http://hhscott.com/93tmv/3-bar_map.htm
http://www.robietherobot.com/storm/mapsensor.htm
has anyone wired a 2 bar up before and know if any wires need to be changed
ok so i checked the connectors, the wiring is the same (both have C B A written on it at hte same wires)
maybe i brought the wrong one????
i got this one
http://www.vpw.com.au/product.asp?Ca...&ProdID=106555
well car runs fine on 1 bar..... stictly not boosting
checked the wiring
both the same CBA for wiring on both, im gonna call up vpw and confirm the one i got works with a commodore, they said it did on the phone but they might have been wrong..
i thought you already had this problem sorted, if you have access to a multimeter you should be able to figure it out. use a piece a tubing connected to the map sensor and blow/suck on it as you measure the output from the pins with the multimeter etc
Body by Holden, Soul by Brock
the Legend will live forever
we figured out the wiring, its the same just if anyone wants to know... , 2 bar is working fine
problem lies with the injectors new set arriving this week
changed injectors to 570cc ones, runs fine and even boosts fine aswell (hit 10psi :P)
