ok i hav a vn 90 model when i rip a stand still some times it lsd's but i noticed when i enter a corner n boot it it never really kicks out just the drivers side leaaves lines.. n i looked under the car n then diff looks original like the mount of dirt n **** on it matches the rest or the car lol
LIFES A GARDEN, DIG IT..lol
depends on the road, went ive done a burnout sometimes both wheels have spun it depends on how level the road is ai think cause on other occations only one wheel has spun.
=Brock=My Ride
2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
it also depends on the condition of the diff, if its been thrashed they have been known to spin twinnies or spin left side only!
We got rep back, yaaay!
[thread steal]
what wheel is the standard one to spin on VN's & VP's without LSD?
[/thread steal]
mine sometimes spins right one then sometimes both.
i think the standard would be the right side, but not really sure
Our diffs are notorious for spinning up the drivers side on both open diffs and worn LSDs.
You can check if you've got an LSD by jacking both rear wheels off the ground and spinning them. If they both spin in the same direction then you're in business. If you put one wheel back on the ground and can spin the other quite easily (i think 68Nm is supposed to be the min torque off the top of my head) then it might need a tighten up (sounds like if it is an LSD it's too loose for your requirements anyway). I've got mine shimmed up so I can only just turn the jacked up wheel by hand. Booting it around corners it puts the power to both wheels everytime. If you're on a budget and reasonably handy at turning a spanner you can tighten it up yourself.
standard is right side.
yer a mate has a vs n his is the exact same..
ill check it when i get the tyres changed over n get my interceptors :P
lsd has red or brown filler bung
my mate had a normal diff and it span twins all the time, but thats cause he flogged the hell out off it and half stuffed the diff.
by the sounds off it to me its a standard diff thats have stuffed
ive been sittin there spinning it an both started spinning, its not impossible mate.. if she kicks out when going sideways its a open diff
lol well we'll just tell everyone its a lsd lol
Thats right, jack the rear up and spin the wheelsl, if both wheels spin in the same direction LSD if they spin in opposite directions then not. EASY
