Results 1 to 16 of 16
Thread: water out of exhaust
    pugga's Avatar
    pugga is offline More Power!!!!
    05 HSV Maloo R8
    Jun 2005
    Baxter
    Default water out of exhaust
    Just a quick stupid question. I've just brought a 89 VN V6 from a mate and there seems to be a heap of water coming from the exhaust. when you rev it up it basically shoots out water. It looks all brown also as in rust?
    The car was sitting in his backyard for a ages and now is garaged
    I can post pics if needed. It just seems to be heaps of water.
    Its just running Unleaded no gas.
    Thanks
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    have you checked out the oil and the radiator fluid to make sure they're where they should be.
    also iirc some engines can put out water as a result of the cat, but i'm not sure how much (doubt it should be that visible anyway)
    pugga's Avatar
    05 HSV Maloo R8
    Jun 2005
    Baxter
    Quote Originally Posted by pow3rslave View Post
    The oil is fine as far as i can see, what would i be looking at with the radiator. the car doesn't see to be leaking anywere. All oil, water levels all seem to be fine.
    Thanks
    VP Executive R-spec
    Jan 2005
    Water out the exhaust when you start a car is 100% normal. If you have ever woken up early in the morning and followed other cars around you will see that they all do it. Also since the car has been sitting for ages rust will come out with it for a while
    pugga's Avatar
    05 HSV Maloo R8
    Jun 2005
    Baxter
    VP Executive R-spec
    Jan 2005
    Yeah but theres no real way that much water can get through the engine and out the exhuast unless it's made in the exhaust from the atmosphere anyway, not without your radiator running dry in a couple of minutes and the engine hardly running
    HoZy's Avatar
    HoZy is offline //There Ain't No Rest For The Wicked...
    BMW E39 540i
    Jul 2004
    S/E Subs, Melb
    When I didnt drive the VN for a month, Water "Appeared" to be comming out the exhaust for a good few weeks when i started driving it again. . . All good after some time. Condensation will sit in your "Cat", "Center" & "Rear" Mufflers.
    MaT
    Quote Originally Posted by garth
    well if it isnt mr i only have temp bans. how long you intending on staying this time hozy.
    pugga's Avatar
    05 HSV Maloo R8
    Jun 2005
    Baxter
    Boonz's Avatar
    Boonz is online now the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    Quote Originally Posted by greenfoam View Post
    that is your baffles coming out the rear as rust
    Jadakiss's Avatar
    Jadakiss is offline Jadakiss Berlina
    1999 Commodore Berlina VTII
    Mar 2007
    Well freind,
    I would be a little worried about the fact that my car pisses rusty water. However, a good clear water in the morning out of exhaust pipe is a sign of a healthy engine. Ask any dumb mechanic! Good luck.
    Jadakiss
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by pugga View Post
    Thanks
    all unleaded vehicles do this .more so on first start up,when car is sitting around for long periods,and it also has something to do with emission control(you see cars driving around with steam/mist from exhaust whilst driving under normal conditions-although not all the time),so if nothing is out of place in the cooling department,it's perfectly normal
    Sep 2005
    Quote Originally Posted by Jadakiss View Post
    Well freind,
    Jadakiss
    nice attitude...but not entirely correct...unless i'm a dumb mechanic
    the rust would only be where the exhuast is rusting,if you read their post he said the vehicle was sitting around for awhile....."hang on" i better check,thats what they said
    holden007 is offline VRII
    Subaru Liberty
    Dec 2003
    If there's alot of water coming out the exhaust, and is continuing doing it, would that be a sign of an head gasket problem?
    Sep 2005
    Quote Originally Posted by holden007 View Post
    well common sense would then prevail.....don't you think? if the cooling system is fine,hence water level has not slipped down,it's not a sign of head gasket,sure it's a tell tale sign,but your cooling system would be down in water.....
  15. #15
    pugga's Avatar
    05 HSV Maloo R8
    Jun 2005
    Baxter
    don't fight over a problem thats not yours
    It has stopped now. I've been running the car for periods of 20 - 30 mins the last couple of nights and it now seems to of stopped and is running better then it was.
  16. #16
    Sep 2005
    [QUOTEOriginally Posted by holden007
    [/QUOTE]
    hey...looks like i owe you an apology....sorry mate.... i read your post wrong,in answer to your question ...yes it is a tell tale sign...
  1. Exhaust Water
    By ducatis in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 07-12-2009, 11:49 AM
  2. water disappearing - water pump - how to change?
    By vh-holden in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-07-2008, 01:30 AM
  3. exhaust pipe looks like a water sprinkler under revs???????
    By Matt_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 17-04-2006, 10:22 PM
  4. Water coming out of exhaust!! need help
    By mattis96 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-01-2006, 05:11 PM
  5. water from exhaust
    By VSIIBerlinaL67 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-07-2005, 07:18 PM
