Results 1 to 12 of 12
Thread: converting a executive to a calais
    Jan 2007
    Default converting a executive to a calais
    is converting a executive model, eg upgrading all options to calais or statesman options ok in a executive and belina
    calais_cruzin's Avatar
    calais_cruzin is offline Calais_Rattling....
    92 VP Calais 3.8
    May 2006
    Gold Coast
    If u want to spend all the time wireing all the dash, climate control, power windows.
    U can do it all but it takes alot of brain power n time to splice all the looms to get to work.
    If i was goin to do it i would do all the seats, trims and maybe the dash pad n maybe just mayb the Lv 3 Dash.
    I wouldnt put in the climate control and power windows if it was my car, too much hassle.
    U could get rid of urs a get a calais for a lil bit more than wat it would cost to get all the parts and then ur time gettin it all fitted.
    And if u werent goin to do it ur self then it would cost a hell of alot more than upgrading into a calais or stato.
    Jus to add ur better off to get calais seats, the rear seat on stato is bigger n needs to be re-trimmed for it to fit so u can close the door, as stato's are wider
    ________________________________________
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by 12000 View Post
    everything should be there ready for hook up,although possibly not the power windows,you would have to go and find a wrecked VN calais to get the power window module and the gear to go along with it,climate control will fit straight in,same dimensions as standard executive,pick em up off ebay for $5-$20,then you'd have your interior to do including roof lining,cluster from memory fits straight in..as for dash pad there is no difference..not in a VN calais anyrate,apart from the badge.which is double sided taped on
    vn ss
    Oct 2005
    VX SS 5.7L M6
    Jul 2005
    W.A. Perth
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If you have a wrecked VN Calais and want to swap all the good bits - go for it. 2 weeks tops to have it all swapped. Its a good idear to use the whole loom from the car you get all the bits from. THEN you will be able to start it after the swap. L3 dash will go in but the trip computer will not work until wired in.
    and 3 Dangerous non ABS VN's
    STEALTHY™'s Avatar
    STEALTHY™ is offline So Wet For You!
    VP Calais International, VP Berlina LX Wagon
    Jan 2005
    SA - The Roadworks State
    Quote Originally Posted by samuels View Post
    you can get a climate control setup for $20?
    I've only ever seen them in 100s
    Quote Originally Posted by davway
    Improved Suspension Reduces Handling!
    Quote Originally Posted by JONNNNOOOOO!!
    cheers sexy
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Just go out and buy a VN-VP Calais mate, save yourself time and hassle.. And atleast when you go to sell it its a 'Calais' and not a mockup.
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
    Sep 2005
    Quote Originally Posted by STEALTHY View Post
    not set up...well actually yeah i s'posse it is,the controller handles it all,but then again you would have to get the ambient temp sensor....,to my knowledge the heater cooling set up is the same,just that the calais has the fancier looking digital face plate with all the options,and is the same dimension as a standard VN heater/cooling switch...after all they are all vaccuum operated
    VN Commodore
    Feb 2006
    statesman seats do fit in sedans. i have a set in my car. they are not wider. they are deeper. as the statemans are a longer car they made the seats so you can sit right back into them. they just have a extra piece so when the back doors are open you can see a bit of the seat. but when shut, ya don't really notice it..
    VN Commodore
    Nov 2006
    the climate control is a lot more than just the control panel.
    I have done the conversion to my vn. there is a lot of stuff that needs to be changed and added to make it work properly.
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    did the full conversion from vn executive to calais options. all power windows, powewr mirrors, central locking, lights in the doors, getting cruise control, set up for level three. just stay with original looms and parts. the problem u might mind is holden keep changing the plugs n that around so its true to get a donor car
  1. Converting to a VN Calais dash
    By stocky in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-03-2012, 09:06 PM
  2. Converting Series 2 VY Berlina to Calais
    By Calaber in forum VY Holden Commodore (2002 - 2004)
    Last Post: 05-12-2007, 03:53 PM
  3. Converting VR Executive light to a VR Calais interior light...
    By sverzijl in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 24-10-2006, 09:46 PM
  4. VR Executive to Calais conversion
    By tr3nt in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-06-2005, 05:44 AM
