Page 1 of 2 12 LastLast
Results 1 to 25 of 30
Thread: Car shaking at speeds above 95km/h
    keza87's Avatar
    keza87 is offline JCCC NSW Member
    VX Wagon S3.8 M5
    May 2006
    Exclamation Car shaking at speeds above 95km/h
    Hi all
    I have a VN S1 Wagon that is running great but have one small annoyance.
    At any speed above 95km/h the whole car shakes! Including the steering wheel.
    So far I have had 2 different sets of wheels and tyres on it, the steering is aligned and working properly.
    I have had the drive shaft out of it once before due to a noisy diff but all is fine with the shaft and centre bearing.
    I have crawled under the car with a set of spanners and tightened about 2-3 bolts that were loose but it still shakes.
    My suspicions are either the drive shaft off balance, harmonic balancer, torque converter or somthing to do with the steering. The reason why I suggest the balancer is that the bolt wobbles with the balancer, but its tight.
    I do a bit of highway driving and it annoys the hell out of me.
    Also the spark plugs and leads have been replaced as my dad suggested a small miss in the engine could be causing it, but have ruled that out.
    Any help or suggestions is greatly appreciated
    JCCC NSW Member
    Check out my ride here : VX Manual Wagon with VZ Senator front end now Supercharged
    Just Commodores NSW Chapter. Join in for a cruise some time!
    Click here for more info
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Get all the wheels balanced, this is what causes a vibration, not the alignment. Rear uni joint can cause a vibration too but it has to be totally f***** and almost falling out.
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    Sorry, forgot to mention that the wheels have been balanced twice as well
    JCCC NSW Member
    VP Executive S2 3.8L
    Oct 2006
    Kingston
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    Bump
    I am really getting annoyed with this problem. Everything I can check myself seems fine. The car has had its steering rack replaced in the past but don't know how long ago. The wheels are balanced and the steering is aligned.
    Every other speed is fine unless it is over 95km/h.
    As well its had 2 different sets of wheels that were both balanced. The stock wheels and mag wheels
    It has its stock suspension. The shocks have been replaced.
    Any suggestions????
    JCCC NSW Member
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    looked at the condition of the front suspension bushes. evil monkey has a stato that use to shake at more than that speed. and his radius rod bush on the front right was missing.
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    engine and trans mounts id check.. or something to do with 4th gear.. does it shake if u leave it in 3? or does it disappear? maybe get ur trans serviced..
    or when u had the center bearing replaced, they didnt align the driveshaft properly and its out.. when did it start occuring? anything changed? or just gradually started getting worse?
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    i'll check the front suspension tomorrow for your suggestion Zuicider.
    The car shakes in 3rd and 4th, tried it the other day coming home from TAFE. the center bearing wasn't replaced as it was still good. The car has done it since I have owned it. I bought it about 10 months ago, it had been unreg. for some time but don't know much about the previous owners
    JCCC NSW Member
    sleek_vp is offline sleek_vp
    VP Commodore V6
    Mar 2007
    brisbane
    had the same problem i had to drive at 90 on a highway a wheel balance solved that maybe your steering is faulty
    terry is offline BT1 VP
    VT Executive
    Apr 2005
    Default shaking bt1
    I have the same problem I have 19,s 245 35 mags new springs and shocks allined and ballanced nothing seems wrong but it still shakes at 80 to 100 no answers but would like to know why as well
    Quote Originally Posted by keza87 View Post
    Hi all
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    I have gone through the front suspension and steering but cannot find anything wrong. All the bushes look good still, the engine mounts are still fine. Next time I am at the wrecking yard I will see if I can find a drive shaft and try that. At the moment I am still annoyed that I cannot find anything wrong!
    The wheels are correctly aligned angd balanced so it cannot be a wheel/alignment issue
    JCCC NSW Member
    Set of thongs
    Dec 2005
    Stonedville
    has the car been in a major accident in the past, the chassis may be outa aline or slightly buckled
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    I can tell the car has been in an accident in the past but don't think it was that bad. The only damage to the car is the rear right panel. Looks like it had been rear ended. The car still aligns correctly.
    JCCC NSW Member
    Burt_vn's Avatar
    Burt_vn is offline Back in the game
    VG V8 5spd, 400hp 5spd soarer, vq stato
    Jan 2007
    Gold Coast
    Yeah this is a tricky one, you say its been doing this since you bought the car? It is definately possible that your chassis has been bent slighty, but i dont see how it could cause your whole car to shake at 90k's and above. Does it go away if you keep speeding up, or is it constant from 90km/h onwards? I'll have a think about this one later.. i better get back outside, gotta finish doing these lifters before the sun goes down :P
    VG ute, 5.0lt, 5spd, twin exhaust, cam etc.
    VQ stato, 5.0lt, auto, pretty stock
    TT Soarer, 400rwhp, 5spd, lots of mods.
  15. #15
    VP Executive R-spec
    Jan 2005
    If the wheel is shaking but the rest of the car isn't it wont be a balanace issue with the driveline, it will be most likely a wheel alignment (take it to a better/smarter place next time) or a worn bearing/rubber/tie rod but I'm going to take a guess that it's running too much toe in and that makes them very nervious at speed, if you are floating all over the road when its wet then that will be the problem
    If the car is shaking and the wheel isnt then it will be a driveline issue. If it's both then I dunno throw it out and get one that's not bent ?
  16. #16
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    Apart from this annoyance this car has been the best car and buy I made. I bought it for $200 unreg. and have been slowly fixing it up and (touch wood) has not broken down in the 10 months I have had it! I have 2 other cars as well that have been trouble since the word go! (not holdens). This has really got me stumped as well.
    The vibrations are from above 95km/h and have only taken it to 140km/h and still shakes at that speed.
    While looking at it today I have noticed the rack has the slightest play in it but don't think that would cause the issue. Or maybe it could be the problem but just don't want it to be
    JCCC NSW Member
  17. #17
    VP Executive R-spec
    Jan 2005
    The rack should have zero play in it and so should the tie rods, even 1mm would make the wheels wobble, if you decide there is movement in the rack there are good people on ebay that will send a rebuilt rack to your door for 200 something dollars
  18. #18
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    Maybe I should look into getting a new rack then!
    Also I am supprised that it is possible to get a new rack for about $200, I thought it would have been more!
    JCCC NSW Member
  19. #19
    1990 VN HSV Clubsport
    Jul 2005
  20. #20
    VP ute
    Mar 2006
    ephect's Avatar
    VS Acclaim V6
    Jul 2006
    another thought.. maybe get ur rotors machined, or if there worn badly, change ur rotors.. does it shack/wobble when u brake?
    just throwing ideas round..
  22. #22
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    All wheels are balanced.
    All shocks have been replaced recently.
    No wobble or shake when breaking plus the the breaks have been done when I bought the car as they were shot.
    Tomorrow I am going to see if it is the drive shaft causing the problem to either rule it out and point the blame to the rack.
    The rack and the drive shaft seem to be the only thing that sould cause it at the moment. Everything else seems to have been ruled out so far
    Thanks for all the suggestions and help so far as well
    JCCC NSW Member
  23. #23
    VN 5.0LTR Berlina
    Mar 2007
    May sound odd but I work at a wrecking yard and one of the
    local mechanics had a VS wagon (NON IRS) that had the same problem.
    He came and borrowed some wheels and tyres that had been balanced.
    He then tried a tailshaft.
    He replaced engine/gearbox mounts. But it still vibrated.
    It turned out to be the LHR axle.
    Banged a second hand one in. Problem solved!
  24. #24
    2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
    Apr 2006
    South australia , Adelaide
    my mates car used to shake pretty bad, he told me one of his cylanders was out and had to be put back in. was fine after that :S
    =Brock=
    My Ride
    2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
  25. #25
    keza87's Avatar
    VX Wagon S3.8 M5
    May 2006
    Thank you for all your help
    I have narrowed down my problem to the drive shaft/axles.
    Today I had the rear end jacked up and let the car idle while in Drive and it shook while the wheels were up in the air rotating.
    I know my diff is on its way out so next time I am at Pick n Pay less I will take the diff assembly out of one there.
    Thanks alcheringa138 for the suggestion as that could most likely be the problem. Whilst rotating the left rear wheel I can hear a noise coming from the axel so it could be one of the few problems with the diff.
    JCCC NSW Member
  1. Shaking in the centre!!!! HELP
    By QWK-11E in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 08-12-2008, 08:35 AM
  2. car shaking at high speeds
    By sebstenator in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2007, 05:27 PM
  3. Shaking Steering
    By brad_m_is in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-09-2006, 06:55 PM
  4. really bad shaking
    By slayer in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 24-08-2006, 10:38 PM
  5. Steering Shaking
    By timboss04 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 14-11-2005, 01:07 PM
