i feel like the biggest idiot, but i locked them in, my old VN has central locking so i don't know how to open it wiout breaking a window. Can anyone help me?????
coat hanger?
your in for a few hours work i had a mechanic an auto sparky me and a mate trying to get in my vn 2 weeks ago, we ended up wedging the top of the door open and using a coat hanger to grab the keys out of the ignition,only way we could get it, tryed blue straps to open the lock tried coat hanger nothing worked, hard car to get into unless u break a window
Blue strap with a wide red rubber band wrapped around it. The rubber grabs the button without slipping off.
[QUOTE=Miss T;555774]i feel like the biggest idiot, but i locked them in, my old VN has central locking so i don't know how to open it without breaking a window. Can anyone help me?????
How hard would it be to get in through the boot? The middle of the seat opens...
scew driver into the key hole swivel up and down till the lock comes out open boot kick the back seat down and ur in
how about prying the door handle out (without damaging the lock obviously)
and then replacing the door lhandle later on?
just a suggestion![]()
well you can try the blue stuff with a piece of blutak on the end of it to stick to the lever or check behind ya number plate cause i had a vehicle once that had an emergency access hole behind it?
Like 2greedy said, check the car.
My mechanic found a spare key above the tow bar (between the boot floor and tow bar)
this, after i had the car 3 years and never knew.
Originally Posted by davway
It really isnt hard to get into a VN. Grab a coat hanger and straighten it out abit. Then feed it between the body and rubber and then twirl it around. Hook it under the button and yank it up, might take a few goes tho.
Selling FG G6E Turbo and buying a N/A Supra
just smash teh quarter panel
:: hakhawk :: says:
im a geek by day
:: hakhawk :: says:
a mass/axe murderer by night
:: hakhawk :: says:
and a rabbit sometimesI'm only nice to one person per day. Today is not your day....
Tomorrow doesn't look good either.
God must love stupid people, He made so many.
Call the NRMA..............
a mate of mine has a honda legend as a family car and his mrs had the key in the ignition and there son locked the doors, so she called him and he was at work and too far away so she called racv and they couldn't get in so they smashed a quarter window to get in. he said what you said. it was the most expensive window in the car.. he wasn't too happy.
why not take the strip of the top of the door. then you can get to the rod.. just don't bend the strip when you take it off. ya still need a coat hanger though. or something like that..
i remember vn's being rated as one of the easier cars to brake in to a few years ago..
coat hanger maybe try the passenger door my drivers side lock is extreemly hard to pull up in my vp .i broke my old vk quarterlite window to get in once cost three times the amount that I could get a windscreen for took a bit of effort too must of hiffed that big rock at least ten times before she broke.better than standing in the snow in the middle of nowhere though.
wedge the rear door open with soming solid(the side with hinges) makes it alot easier to get coat hanger in. this is wot the rac will do. other wise listen up and mikey will tell u how to get in....... grab a drill with a small bit on it...mabey as thick as a coat hanger....drill just under the lock surround inbetween the plastic and door panel....feed coat hanger in and lift up the lock from indide the door. this worked very well for the ppl who stole my bros amps, speakers and subs out of his car. the hole isnt very noticable at all. lol
personally id rather stick with my first idea
jokes..ahahaha i get jokes
using a 300mm ruler slide virticle about 50mm from edge of door
this should take 3 seconds butta bing butta boom
Research has shown that men usually sleep on the right side of the bed.
Even in our sleep we happen to be right.
Powered By Garrett
just pull the window done just need 2 people my mate did it to his car once
__________________
R.I.P AAA-99P you will be missed !!!!
i have parts for vr vs vn vp for sale check them out .. they worth the look!!!! http://forums.justcommodores.com.au/...-look-nsw.html
just pull the window down just need 2 people my mate did it to his car once
__________________
call the NRMA.
The Vn's have got to be one of the easiest cars to break in cause of the lock which once u got a coat hanger in, it simply justs able to push up the lock
