Page 1 of 2 12 LastLast
Results 1 to 25 of 27
Thread: Brakes RE: V/N/P/R
    azkwazere is offline Ahhh Yes, Ahhh Yes....
    VP 5-SPD / 24-SPD Racer Hybrid
    May 2005
    .....SE Burbs
    Default Brakes RE: V/N/P/R
    1. Will VR rotors bolt up to VN/VP's?
    2. If "no" is there adapters that enable this?
    3. Can standard pads be used with slotted + coss drilled rotors?
    4. Do i need a bigger master cyclinder to run bigger discs?
    5. Are rear brake rotors the same as front brake rotors?
    Than guys/girls.
    aZk.
    Wanted to buy:
    1. T5 V8 Bellhousing and Clutch fork assembly suit VP
    2. V8 Tail Shaft, T5, Suit IRS VP
    3. T5 VB Gear Box
    PM Me if you got what i need...
    Quote Originally Posted by ryno_vrx View Post
    honestly i doubt it will happen cause kanye west will just interrupt Armageddon anyways
    Zuicider is offline Banned
    Set of thongs
    Caribbean Stud Poker Champion!
    Dec 2005
    Stonedville
    vr rotors should if its non abs, standard pads can be used with slotted. if your keeping your brake calipers the same a larger master cyclinder shouldnt be required. rear rotors are not the same as front rotors. as front rotors have bearing cups in them to attach to the hub while rears slide over the hub on the diff
    Set of thongs
    Dec 2005
    Stonedville
    May 2005
    .....SE Burbs
    thanx mate!
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    vr/s rotors wont fit a vn/p without hub adaptors.
    you can use normal pads with slotted/drilled rotors, tho they will chew through quicker(on any pad)
    front and rear are different.
    it would pay to go a bigger master cylinder with bigger discs, as they usually get quite spongy when bigger discs are used with stock master.
    and the finned vr calipers will bolt up to vn, but you need to run the vp 289mm discs(which is a good thing, as the vn's are 270mm stock)
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Quote Originally Posted by azkwazere View Post
    1. Will VR rotors bolt up to VN/VP's?Nope and why would you?
    2. If "no" is there adapters that enable this? Nope.
    3. Can standard pads be used with slotted + coss drilled rotors? Deffine standard pads? It makes no difference.
    4. Do i need a bigger master cyclinder to run bigger discs? No, you only need a bigger MC when you change calipers.
    5. Are rear brake rotors the same as front brake rotors? Nope.
    Than guys/girls.
    aZk.
    See above.
    Selling FG G6E Turbo and buying a N/A Supra
    May 2005
    .....SE Burbs
    Quote Originally Posted by hakhawk View Post
    thanx troy, thinkill just get the group A upgrade... tis only 800.... worth it, hows your cars going? should come round n seem some time...
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    hakhawk's Avatar
    Jan 2005
    yeh, grp a upgrade sounds the go, and get a new 1" master cylinder aswell.
    cars are going alright, got some bits for the vp at work today for steering rack.
    just added you to msn if you wanna jump on there and chat.
    where abouts are you living atm? ur location says 10 outta franga, which is just a wee bit from me still
    May 2005
    .....SE Burbs
    dont use msn... its gay :P
    im in churchill (10 outa tralalalalalagon lol)
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    hakhawk's Avatar
    Jan 2005
    lol, kk.
    drop down to autobarn between 11 and 2 tomorrow, im working lunch shift.
    look for the dude with glasses.
    thats if you're not doing anything.
    May 2005
    .....SE Burbs
    coolieos.. ill comedown n see ya!
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Group A for $800
    I would check that, I have never seen them for under $1K.
    VP Executive R-spec
    Jan 2005
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by greenfoam View Post
    You ever looked on ebay maybe fake group A but the same thing :P
    They use the Group A rotors but the C5 calipers not the C4's.
  15. #15
    May 2005
    .....SE Burbs
    Quote Originally Posted by AirStrike View Post
    i dont care... its a serious upgrade form what ive got... and the rotors are bigger than the VT upgrades, im happy!
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
  16. #16
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    aZk.
    Not saying its not a good buy, just not the group A setup so expect a slightly sponggy pedal.
  17. #17
    May 2005
    .....SE Burbs
    what is the difference with the c4 and c5s? is there a bigger MC than a 1"?
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
  18. #18
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    aZk.
    The C4's use a 4:1 booster and a 1" master cylinder. The C5's use a 4.25:1 booster and a 1" quick fill master.
  19. #19
    minux's Avatar
    minux is offline Infidel Bear
    300rwkw FG G6ET/2011 Sti Spec R Hatch
    Mini Putt 2 Champion!
    Feb 2005
    You could always go these?
    http://holmart.com.au/online/prod1520.htm
    I'm seriously contemplating buying because its a darned good price.
    "Be who you are and say what you feel, because those who mind don't matter and those who matter don't mind."
    - Theodor Seuss Geisel
  20. #20
    May 2005
    .....SE Burbs
    Quote Originally Posted by minux View Post
    Bit out of my league.... and almost near overkill, VNs arnt that heavy!
    It wont bolt up anyway.... would be nice though!
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
  21. #21
    May 2005
    .....SE Burbs
    so the group A kits come with a c4 then? ... can you use a 1" quick fill on a c4? or is it pointless?
    that, and how much difference does a 4 - 4.25 make?
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
  22. #22
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    aZk.
    All you need is the $250 coversion hubs to do the fronts.
  23. #23
    May 2005
    .....SE Burbs
    Thats 3K worth of breaks for..... isn't there like a threshold of usefulmess though? like, how much more difference is the HSV kit gonna make over the Group A kit?
    aZk.
    Wanted to buy:
    3. T5 VB Gear Box
  24. #24
    minux's Avatar
    Feb 2005
    aZk.
    ALOT, i thought much the same when i went from slotted standard VT brakes to my PBR setup(343/289) and damn i couldnt imagine living without them. Going to this kit would be even better. Brakes can never be too good.
  25. #25
    anton1o's Avatar
    anton1o is offline [GMHVN6]
    VN 6 Berlina '90
    Jan 2005
    West Subs,Melbourne
    Im running this setup on my VN6 and it brakes incredibly nice and smooth comparing to stock.
    DBA Slotted Front Rotors
    Bendix Ultimate Pads(incredibly DUSTY)
    SuperDOT 4 Fluids
    Next upgrade will be doing the rears.. You can really push your car harder when youve got the safety of stoping much later and much smoother.. I rarely go more then half way on the pedal.
    ride; [GMHVN6] Project Streeter - VN Berlina '90 mods; 65mm throttle-body / Cold Air Intake / 8mm Ignition Leads / Exhaust
    future; Extractors , Cam currently; 101.2rwkw mission; 110rwkw
  1. VZ HSV brakes
    By GROWLZ in forum General Discussion
    Last Post: 17-11-2009, 04:32 PM
  2. brakes help!!!!!!!!!!!
    By vn_lexcen_s2 in forum General
    Last Post: 06-09-2006, 12:24 AM
  3. Brakes
    By savage1987 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 05-09-2006, 09:55 AM
  4. VK brakes
    By brettyb2002 in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 27-05-2006, 08:01 PM
  5. Brakes
    By mitch01 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 01-11-2005, 03:45 PM
