I'm sure I'm not the only VN/P owner what has a very loud clunking rattle that seems to come from inside the doors or infront of the doors (mostly the drivers side). Well as I was driving home tonight, clunk clunk over the bumps on the highway and I had a revelation and realised that these clunks are related not really to bumps well they are but it's more that that, these clunks can also be made by cruising slow and accelerating slightly, just enough to give the body a bit of torsional twist but not enough so that the engine makes too much noise so you can still here the clunk.
Well each time you give a little power you get a clunk, everytime you go over a bent bit of road you get a clunk it's caused by flex in the car and when the car flexes the worn out pins in the doors must bash the inside of the hinge and go "Clunk, clunk" so one of my next jobs on the vp is to replace the door pins to see if this cures the "big" rattle in the car![]()
hmm my old vp had this, if i still had it i would be enlightened!
We got rep back, yaaay!
maybe check you check strap too because they have a habbit of screwign up on older cars
LIFES A GARDEN, DIG IT..lol
Bonnet hinges rattle too and sound like it comes from the door. My rattle turned out to be the bonnet catch was loose lettling the bonnet rattle and transmit back to the door. I pulled the whole door apart but could not stop the rattle. Door pins - can you move the door up n down when open?
and 3 Dangerous non ABS VN's
Yeah man the door pins are worn a bit on the drivers door for sure. But they weren't so bad on my old VN and it made the same noise but from both sides. It's just a really anoying noise because ALL the roads I drive on are very rough and it's constantly clunking away. If I get on a Melbourne style smooth road then you will never hear it at all but out here in the sticks I really can't have this kinda loosness :P so I have to fix it
And the bonnet post n spring is tight? Oh just a thought can you take the car for a spin with the door off!!
I may add here that the VN wagon is (fingers crossed) rattle free for now![]()
good work 88GreenVN, thats probably one of the only vn's that does not have some sort of a rattle... greenfoam can you still buy those door pins new from holden cos mine are slightly bent from all the clunking going over potholes and stuff and they give the loudest squeek ever when i open the door, its giving me the s**** and its a bit embarrassing getting out of the car... cheers
You should be able to get the pins and all that stuff, you can still buy pretty much every part for a VS and luckily alot of these kind of parts are the same on the VS. I'll let you know how I go with this rattle fixing adventure in the next week/s![]()
Ill be keepin an eye on this thread, good luck greenfoami always thought it was the door latch not locking tight, but ive never really bothered taking a proper look.
VG ute, 5.0lt, 5spd, twin exhaust, cam etc.
VQ stato, 5.0lt, auto, pretty stock
TT Soarer, 400rwhp, 5spd, lots of mods.
i found my rattle.... as 88greenvn said it was the bonnet hinges, i only found that out when i took it for a drive after i put the new engine in before i put the bonnet back on. i also found out its only the drivers side as the passenger one has been replaced.i havent had a look at them to see if i can remidy they problem yet because im too slack. but when i do have a look and if i fix the prob i will post and let you all know what and how to fix the prob.........if i fix it
Stato on the inside, berlina on the out side,5ltr under the bonnet,stockies all round...........that thing has to be a sleeper
MY RIDES
[SIGPIC][/SIGPIC]
http://forums.justcommodores.com.au/...ad.php?t=41837
$2.50 a pin i payed from motor traders the big hint of door pins being stuffed is if you can move the door up and down when open.
im not admiring your car im looking in disgust
I hate rattles and clunks ant that kinda stuff, i have a vr, and i think i might know of the one you are talking about, sounds on mine like it comes from under my feet, but its not all the time, only sometimes, and usualy on a moderate bump, and i think i sometimes get it on the accel that you talk about too, i was starting to think i mighta left something loose after refitting my k frame, but i have checked everything that i had off, and its all still tight, but i have one for the ute owners out there, ever had a rattle that sounded like it was coming from behind the trim panel right next to your right ear that goes around the quarter glass? Well, i pulled it all off, drove it for a week like that, still there, so i thought it might be the outer trim, but nothing that could rattle there either, if i gave the guard a light tap, id hear it, i still couldnt find it tho, then i lifetd the tonneau up, and found it right away, the panel on the inside over the fuel filler area, i took that off, and now rattle free for 3 months and counting, ill get around to deadning it soon and putting it back on and see if its still gone, but ill be watching to see how the new door pins go, i know mine are worn, so that might be it
Yeah my passenger door rattles like crazy. Drives me nuts. Its the only rattle in the car. Lets us know if you can fix it in your car, then every will be playing with their doors.
The pin on my VN is quite worn... or rather, the mount that holds the pin. Its able to move nearly 1cm - opening the door gives quite a nice groan and driving it does rattle too. One of these days I'll have to see if I can get a larger pin to stop this movement in the mount - the pin itself isn't worn that bad. Or perhaps a small spot of weld to make the mount smaller again
Good tip on the bonnet, I think thats also the cause of some rattles.
Followed by something along the lines of the strut or suspension![]()
OMG write a how-to!!! Get it stickied in this section, every VN/P owner needs it!
I just fixed a maxi-rattle in my VN yesterday, removed the spare screws I had lying around in the centre console 'just in case'... ALL 35 OF THEM!! WTF! I'm sure I never put them all there....
My interior is slowly getting better, doing a conversion of EVERYTHING to VP blue-grey, so dash swap no.2 is coming up, amongst other work... spent 2 hours on the front window mechanisms alone the other day, they are better now... Unfortunately driving on highways is a lot louder without the roof lining in the car
My poor VN, it's getting closer to having all its clothes back on!!
Sam
WTB: mulberry VN interior parts
