as the title suggests, i have a mate whos having problems with his VN, it stalls or goes into limp home mode once it warms up and i suspect it to be the CAS but i have no idea where it is to test so if someone could tell me it would be a great help.
We got rep back, yaaay!
Big bottom pulley.
When it plays up u throw a bucket of water on the pulley to cool the sensor n she should run perfect, if it dont fix it it either the sensor is really stuffed or it not the problem.
Check codes, i think its 42 43 if i remember right.
Its only a bad idea to put cold water in the radiator if the engine is hot. Throwing cold water onto it shouldnt be a problem (ive done it a few times and never had a problem). Infact putting cold water into the radiator of a overheating engine will probably do more damage to the engine than the overheating.
Im not a complete idiot, some parts are still on backorder!
so thats the big pulley just behind the radiator?
Yep the big on at bottom behind radiator
sweet as cheers calais_cruzin
