Results 1 to 6 of 6
Thread: -help--horn to steering wheel
    ben k's Avatar
    ben k is offline ben
    VP Calais S2
    Aug 2005
    radelaide...bay area
    Question -help--horn to steering wheel
    hey
    one of the reasons im off to regency is that my horn wasn't attached to my steering wheel and this was due to 2 of the black plastic studs that attach the horn to wheel breaking off
    had a shot at removing them by unscrewing them but the soft plastic just crumpled under a pair of pliers
    wondering if it is possible just to remove these studs and replace them or will have to get a new steering wheel?
    any help much appreciated
    sorry for the pic quality off my phone
    Attached Thumbnails Attached Thumbnails -help--horn to steering wheel-steeringwheel.jpg
    VT SS 5.7
    Aug 2006
    Western Suburbs/Melbourne
    I had the same trouble with my Calais steering wheel and the way i worked it out was to take the steering wheel off,cut the clips flat,then glue some new clips to the base of the wheel (i used a clip they call "christams tree" clips)
    Then reassemble and the horn pad will accept these new clips
    ben k's Avatar
    VP Calais S2
    Aug 2005
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    I just fixed my Calais wheel with the same problem. I cut the broken lugs flat. Drilled a hole into the centre of the lugs on the wheel. I cut the donor lugs from a standard VN horn and drilled a hole in the centre of them too. Cut a small bit of welding wire that fitted the hole and used 5 min araldite to glue them in. Worked a treat. I have pulled the horn pad on and off about 10 times and alls good.
    and 3 Dangerous non ABS VN's
    ben k's Avatar
    VP Calais S2
    Aug 2005
    sounds even better
    buuuut wouldn't that require another steering wheel...?
    88GreenVN's Avatar
    Jun 2006
    No just the horn cover. Here is some picks of the donor horn plastic bit and the finished job. Hard to see the repair but you can see a dribble of glue.
  1. Boss kits for VT steering wheels to fit a VZ/VY steering wheel?
    By nEb. in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 27-12-2011, 07:28 PM
  2. SAAS steering wheel bolts, horn, rattle??
    By gupatrol in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 03-12-2007, 06:14 AM
  3. Vr Steering wheel Horn
    By G4orce in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-10-2006, 02:29 PM
  4. Your thoughts on replacing steering wheel with airbag to a MOMO wheel....
    By *VOLATILE* in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 04-02-2006, 08:36 AM
