Chuff
- Nov 18, 2004
- 225
- 0
- 16
- Age
- 56
- VE V8 Calais
In a VP 5L engine the distributor used is a High Energy Ignition - Electronic Spark Time (HEI-EST).
It is located at the Rear of the Valley.
The Distributor distributes the High Voltage Spark and contains the Crank Angle Sensor.
The Crank Angle Sensor is a Hall Effect Sensor.
Could someone please explain what purpose the Crank Angle Sensor has in a 5.0L VP engine.
It doesn't have a coil pack, or sequential injection, so what's the point? What does the ECU do with this information, if anything at all?
The reason I ask is I'm trying to ascertain whether or not the installation of the distributor should take into account the Crank Angle Sensor setting.
Thanks!
CATCH!
Thanks!
CATCH!
