Hi
Im pulling the diff out of my VN Calais but most of the bolts seem to be seized. Whats the best way 2 go about this, angle grinder? lol jk. Also will holden be able to sell me new bolts for the rear end? how expensive are they if they exist.
Thanxs
Plenty of CRC or similar and wait over night. They will be tight but once cracked should come undone.
thanxs, can i buy new bolts? or do i have 2 clean up the old ones
if you take some samples to a bolt shop you should be able to set you up wit some new ones.. not sure on prices but i woldnt think they would be rare or anythin so should be reasonable..
LIFES A GARDEN, DIG IT..lol
do as not an abba fan has suggested, and if they wont budge, slide some metal pipe of the spanner, 1-2metres long and it should 'crack' loose
EDIT: lucky u, got my 500th postwoohoo
ok bolts around tailshaft flange are still seized. I cant get a socket on em and theres not much room for a large bar under the car what should i do? any ideas are apreciated.
Thanxs
cut them off. although you will have to find new ones then.
14 mm spaner and a 15 mm spanner, just apply lots of pressure and they should crack no worries, if not as mentioned wd40, rp7 or CRC go hack and crack in the mourning
