Results 1 to 13 of 13
Thread: lsd and non lsd diff pinions
    hakhawk's Avatar
    hakhawk is offline smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    Default lsd and non lsd diff pinions
    hey guys, just watching a live axle lsd centre on ebay, but it has no pinion gear.
    would the pinion gear from a stocko diff centre fit?
    and whats the average going price for a second hand lsd centre these days?
    cheers
    troy
    hakhawk's Avatar
    Jan 2005
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    Crownwheel & pinion are a matched set. As for theprice of a 2nd hand LSD I dont know, just ring around a few wreckers.
    VN 5 spd/VR Calais daily driver
    Mar 2006
    NZ
    Yea just change the crownwheel over to the one on the car now so you keep it with its matching pinion. Or it would be a good time to upgrade to some shorter ratio diff gears if you haven't allready done so. The 3.45:1s from a VL are cheap and were perfect for my manual, not sure what they're like on an auto though.
    hakhawk's Avatar
    Jan 2005
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    Yes it should still fit. However you may need to reshim the carrier bearings to get the contact & preload right.
    hakhawk's Avatar
    Jan 2005
    cool cool, ill see if i get it cheap, then ill chuck it in, see how it goes, if it needs stuff done, ill take it back out and get it done sometime
    cheers for the help
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    When you wack it in make sure there is some backlash between crownwheel & pinion. Im not 100% sure on the exact amount just as long as you can feel some it is fine. (Is in my speedway car anyway)
    YMY-88U's Avatar
    YMY-88U is offline Donating Member
    Project VH SL/E
    Jun 2005
    Question
    sorry to dig up an old thread but im wanting to install a lsd in my car and have found a few on ebay and just wondering if this here is all thats needed for it to be an lsd, sorry i dont know much about this sort of stuff so any help is very appreciated, cheers guys
    http://cgi.ebay.com.au/4-Pinion-LSD-...QQcmdZViewItem
    Mar 2006
    NZ
    Yes that's all you need for it to be an LSD. It doesn't come with the gears though so you'll have to bolt your crownwheel onto it (if you're not going to change the ratio at the same time).
    YMY-88U's Avatar
    Project VH SL/E
    Jun 2005
    ahh ok cheers for that, maybe ill wait a little longer and get a vl turbo diff with the 3.45 gears
    VP MANUAL S/C 3.8 UTE
    Nov 2006
    Country Vic
    Just remember if you are getting a lsd with the diff gears make sure you get the both crown and pinion gears as they are a matched set and you can not mix and match
    Mar 2006
    NZ
    Quote Originally Posted by 91_Berlina View Post
    If you can get that LSD on ebay for cheap it would be worth going to the wreckers and getting a set of 3.45:1 gears off a 6cyl VL to bolt onto it.
  1. V8 Diff vs 6cyl Diff
    By RSO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-04-2009, 09:45 PM
  2. diff making a noise / replacing diff
    By yipya in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 17-12-2008, 11:30 PM
  3. Putting in new diff oil and replacing diff gasket ?
    By gemini in forum VL Holden Commodore (1986 - 1988)
    Last Post: 07-10-2007, 05:22 PM
  4. 3.45 LSD Diff
    By MONVTARO in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 20-12-2005, 07:44 AM
  5. 3:08 diff to a 3:45
    By greatone in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-11-2005, 10:20 PM
