Hey everyone, just curious as to how to get the handbrake handle off? I want to replace mine with a chrome Isotta version, but i've never removed one before?
Does it just twist off? I had a go but it didnt wanna budge?
If u just takin off the rubber, it will just twist off, maybe heat it up a bit first.
Mine is loose as.
Whats this Isotta one like, u got a pic?
Add: That looks sweet, i wouldnt mind gettin one of those.
This one:
Im getting it with a blue leather boot though.
Bumpety, is it just glue that holds it on? Because I tried the one in my VS as well and that too wouldn't budge.
Yeah keep tryin, i dont think there glued on just really tight, maybe leave ya car in the sun then give it a go.
Just keep twisting it, it will eventually break wateva seal it making
1. Soke a tea towl in hot water - put some plastic down - and wrap the hot tea tow around it. OR 2. Get the hair dryer. OR 3. Heat gun OR 4. Oxy always worked.
and 3 Dangerous non ABS VN's
did you end up getting it off???
__________________
R.I.P AAA-99P you will be missed !!!!
i have parts for vr vs vn vp for sale check them out .. they worth the look!!!! http://forums.justcommodores.com.au/...-look-nsw.html
Nah not yet, I aint at home. Im at uni, then have work 3-11pm, so I doubt its coming off today.
ok .. let us no when you get it of .. cheers
__________________
I got it off, its just a matter of braking the seal then twisting it side to side til she pops off.
Got the Isotta one on now too, which is held on by four small allen key screws instead of being slide on slide off.
Havent done the leather boot yet though. Is there anyway to remove the leather boot without pulling the hole centre console out/up?
I really cannot be stuffed removing the centre console section...
i removed my hand brake handle and the pin fell through now i got no brakes at all (steals thread) how do u get that pin back up to push the rubber button on without taking the whole assembly out
