Results 1 to 7 of 7
Thread: Oil pressure sensor
    VNSS Atlas Grey
    Feb 2006
    Default Oil pressure sensor
    hey guys
    um i have just found that i have oil leaking out from the oil pressure sensor and i would like to know how to change them over. just unscrew it?
    and also i think it also leak from my dipstick ( right down the bottom in the sump) how do i replace this?
    VN V6 0-60mph in 7.52
    Peter Brock
    Morton's Avatar
    Fairstar the Funship
    May 2006
    Oil Pressure Switch just screws out with a good shifter. New one won't set you back more than twenty bucks on a bad day. Not sure about the dipstick off the top of my head.
    The 1972 HQ Kingswood
    VN Commodore
    Feb 2006
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    VNSS Atlas Grey
    Feb 2006
    thanks alot guys
    just rang up for the sensor set me back $25 bucks which i spose isn't that bad. How do i get to the o ring but will i need to take the dipstick off? if so how do i remove it?
    Cheers guys thanks for your help
    Peter Brock
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Not sure if there is a bracket holding the tube to the engine, usually about 1/2 way up or it may even be on the base of the tube, once you have undone it, just pull it up.
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Just undo the bolt holding the bracket of the dip stick, then pull it out the O-ring will just slip off so just take the O-ring up to a place like Bursons or sprint wont be much could even get it from a rubber joint (clark Runbber)
  1. VN S1 Coolant sensor - Will a V8 sensor fit/work in a V6?
    By mulligan-can in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 07-05-2007, 09:08 AM
  2. 202 Oil Pressure? anyone know?
    By vasrox in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 02-12-2006, 08:14 AM
  3. oil pressure sensor aldl
    By Matt_vp in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 16-05-2006, 10:44 PM
  4. oil pressure gauge, oil pressure
    By VN-88 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 09-10-2005, 10:31 PM
