Results 1 to 14 of 14
Thread: Engine cutout!?
    Calais3800's Avatar
    Calais3800 is offline KALAIS_KRAZY
    VN Calais v6
    Apr 2006
    Frankston district
    Exclamation Engine cutout!?
    hi everyone, the other day i was idling at the lights and my motor cut out. it would not restart!! i could hear the starter clicking away but it couldnt start. i had to get a tow home.
    But then 3 days later i tried it and it started and reved straight up no probs. i dont want this to happen again. does anyone have a clue what this could be?Its a Vn Calais V6. i thought maybe the immobilser is starting to play up. any ideas??
    Fourtune Favors The Bold!
    car
    Jul 2006
    greensy, melb
    if all u could hear was clicking it means the battery was nearly dead so im guessing the alternater is on its way out that is why ure car cut out and u couldnt start it again cos the car drained the battery
    im not a 100% sure but thats my guess
    "A life lived in fear is a life half lived"
    Calais3800's Avatar
    VN Calais v6
    Apr 2006
    Frankston district
    could be. i hope its that simple coz i cant find the immobilzer ...and its not in the manual. Funny thing is i tried the immobilzer key switch in the glove box and it starts in both positions. i wonder if both r worn out?? does anyone know a simple test?
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by Calais3800 View Post
    you don't want to know where your immobiliser control unit is,you nearly have to remove whole dashboard to get to it.it wouldn't be your immobiliser causing it to just die,as you have disabled the unit completely when you use your remote,that thing you are talking about in the glove box,arms and dis-arms the security system in your car.
    just by what you are saying,it is sounding like the battery,when your alternator goes....or on the way out,usually but not always,everything flares,instrument lights indicator lights,interior lights,etc,etc,so when you turn something on it flares your cluster lights,headlights,etc,etc...know what i mean..also your charge light would come on,cheapest and easiest solution for now is see if you can borrow a battery for a few days,and see if it does the same thing with different battery,other wise,bob jane do free battery testing,well down here they do
    if you have access to a multimeter and know how to use it,test your alternator
    Black VN MANUAL
    Feb 2007
    Top of Vic
    Is it running hot going thro water/coolant? could be waterpump. water leaking into the CAS (crank angle sensor) so your car wont start untill it drys then it could happen again if problem not fixed see if the sensor wire has the seal around it.
    Calais3800's Avatar
    VN Calais v6
    Apr 2006
    Frankston district
    Question
    Quote Originally Posted by samuels View Post
    Nah my calias doesnt have a remote. i have to use the key....sucks. My battery is good quality zero maintenance type bout 3 years old and has plenty of power, she starts easily in morning no probs at all. Nah no coolent loss either. So far sounds like the altenator, but the warning lights never come on! weird! lol. No
    its been bout 4 weeks now and its still running fine ,no cutouts.....but in order for it to cut out like that there must be a fault somewhere. and i really dont wanna break down at bizzy lights in frankston again. waz total stress out.lol.
    The day it cut out there waz heaps of power left in battery too, i could hear the crankshaft turning ova but it waz like there waz no fuel mixture getting into the chambers.Or maybe there waz mixture but there waz no spark?
    hhhmmmm,dunno. wat do u guys think...... Maybe fuel system/ignition system??
    this is seams to be one of those neadle in a haystack engine faults.my ideas so far....
    Faulty:
    Immobilzer (website) http://au.geocities.com/commodoretech/nelect.html
    ECU
    Altenator
    Fuel system (blocked fuel filter/worn pump?)
    Ignition (worn coil pack/plugs/leads?)
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    If the security switch in the glove box is faulty it will cut power to the injectors - so no start. I had my car running and put a screw driver (no key) in the lock and gave it a wriggle car would cut out every time. Buy passed the lock (dash half out) and problem went away. To add to that My DFI unit fried itself along with other electrical bits and the ECU went west a few weeks later. All fixed now though.
    and 3 Dangerous non ABS VN's
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by vq statesy View Post
    correction, when its flat not to crank, you'll hear the relay going nuts like CLICK CLICK CLICK CLICK
    are you sure you had it in gear when you tried starting it???? like it mean mine sometimes starts in netural but not always, always starts in park well tries to atm :P
    the common issues for this problem is
    a)Crank Angle Sensor
    b)DFI moduel (this was the case for me) its the coil back circit board
    c)ECU (usually goes beserk)
    Calais3800's Avatar
    VN Calais v6
    Apr 2006
    Frankston district
    Question
    Quote Originally Posted by PaRaDoX616 View Post
    no, not "in gear" but i did cycle between Park and Neutral a dozen times, trying to turn it ova eventually the battery drained and then i got the clicking from the relay. 3 days later she stared up on her own! x-file style baby. The battery must of charged itsself bak up??
    Theres some god ideas here though, i didnt think of the DFI. The thing is im gonna need a multimeter to test all this stuff.
    If i short out the Diagnostic loom with some wire and do the Fault test will these problems come up?? i have the vn manual with all the fault codes. does anyone know?
    Calais3800's Avatar
    VN Calais v6
    Apr 2006
    Frankston district
    Quote Originally Posted by 88GreenVN View Post
    Mine starts and runs even with me wiggiling the immobilizer key in the immobiler key switch. Mine must obiously be faulty and it waz a hot day so maybe the heat caused a malfuntion. I thought about bypassing it or even just getting an aftermarket replacment. but now that u say its behind the dash its gonna be one hell of a job. thanks for ya help ppl!!
    JD
    JD is offline Donating Member
    VS Berlina
    Aug 2006
    Deep South, SA
    i reckon alternator, as my VP had this problem, it would go flat and die but after 15mins it would start again and slowly go flat.
    We got rep back, yaaay!
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    If it was a hot day then maybe the CAS is on the way out. Sometimes they cut out once, then it could be 2 months later and it dies altogether. Just do a code check because it should have logged an error, but it clears after so many starts so it may not show.
    car
    Jul 2006
    greensy, melb
    [QUOTE=PaRaDoX616;565432]correction, when its flat not to crank, you'll hear the relay going nuts like CLICK CLICK CLICK CLICK
    thats excatctly what i meant dude, he heard clicking so he prob thought it was starter motor
    Calais3800's Avatar
    VN Calais v6
    Apr 2006
    Frankston district
    yeah it waz clicking. but for first 10 mins the motor waz trying to turn ova/start but woulndt for some reason. And theres no waring light coming on for alternator. im sure its something else...ah well.
  1. intermittant cutout in cruise
    By Panama in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-11-2007, 11:15 PM
  2. VN Engine - Signs of failed engine valves
    By nolim8ts in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 30-04-2007, 07:15 PM
  3. SYDNEY -VY or VZ roof lining with s/glass holder cutout
    By Marks-VY in forum Parts And Other Items For Sale
    Last Post: 24-09-2006, 10:48 PM
  4. ALOT of engine movment... not broken engine mounts
    By commy92 in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 26-04-2006, 10:14 AM
  5. auto indicator cutout faulty
    By kooloo in forum VB - VK Holden Commodore (1978 - 1985)
    Last Post: 19-10-2005, 05:55 PM
