Results 1 to 8 of 8
Thread: Climate Control Install??
    'Ruby' 1991 VN Exec & '98 Proton M21 Coupe
    Chain Reaction Champion!
    Feb 2006
    North Tassie
    Default Climate Control Install??
    While I was thinking about electric mirrors, I also thought of climate control.
    What is needed to install this apart from the main unit? If I was to go to a wrecker and get all the stuff what else would I need?
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    a mass/axe murderer by night
    :: hakhawk :: says:
    and a rabbit sometimes
    I'm only nice to one person per day. Today is not your day....
    Tomorrow doesn't look good either.
    God must love stupid people, He made so many.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    The complete HVAC box, along with the climate resistor and climate control loom... I would take the entire loom if I was you. But you need the green climate plug on the loom as this needs to be wired into your loom.
    Also, you need the solar sensor which sits in the demister vents and the ambient temp sender which sits at the front of the car somewhere... There are plenty of pics in my ride thread (around page 21 i think) of all the bits needed.
    I have to finish the instructions for this too... I forgot hehe...
    NickVR's Avatar
    NickVR is offline Donating Member
    VR Executive A4 V8
    Jun 2006
    Adelaide, SA
    If you were in SA you could go to Just Commodore Spares, they quoted me $550 for all parts need. Bit expensive most prob. I've seen full conversion kits on ebay for a VR/VS go for around $250.
    1991_Vn2nV's Avatar
    Mar 2006
    Feb 2006
    North Tassie
    Hurry up do the How To please!!!!!
    Hahahaha, I'll check out your ride thread, then I'll start scouring for a cheap set of the parts. Was it hard to do?
    :: hakhawk :: says:
    im a geek by day
    :: hakhawk :: says:
    :: hakhawk :: says:
    1991_Vn2nV's Avatar
    Mar 2006
    Umm the wiring is the easy bit..
    Getting the heater hoses through the firewall is a pain in the ass and the swapping of the HVAC boxes in general... And you might wanna drain the cooling system if you dont want coolant everywhere as it leaks out the HVAC box when you remove it.
    Other than that... Getting the dash back in can be a pain too, especially getting it to sit 100% correctly without a rattle. My centre console has dropped down on the left hand side but I can fix that, also I had an issue with the fusebox cover as it seemed to not be large enough when I put it back in, but it was because I had a loose screw on the left side of the dash so the dash was sitting out a bit at the bottom.
    hsvtj's Avatar
    hsvtj is offline now cruising..
    VK wagon, VS Statesman 5.0
    Jul 2005
    Berwick
    What is the difference between the aircon setup and the climate control setup??
    apart from the electronic control on the climate control?
    1991_Vn2nV's Avatar
    Mar 2006
    Quote Originally Posted by 1991_Vn2nV View Post
    My post here pretty much explains it...
    The HVAC boxes are different... As in the heater box. Theres a climate loom which needs to be added (it has 10 wires in it [though 1 wire splits and goes to two sensors]). Theres a solar sensor in the demister vents and an ambient temp sender near the radiator.
  1. Climate control install
    By statesman_wagon89 in forum Electrical Wiring / Questions
    Last Post: 13-05-2006, 02:40 AM
  2. Cruise Control and Climate Control?
    By Mr_mystikal in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 23-04-2006, 06:29 PM
  3. VT Climate Control
    By Johnny_H in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 05-03-2006, 01:06 AM
  4. vx climate control install
    By get1 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 03-10-2005, 06:07 PM
  5. Climate Control!!!
    By bp95berlina in forum Electrical Wiring / Questions
    Last Post: 27-08-2005, 08:43 PM
