Results 1 to 7 of 7
Thread: help me with probs on superlow and jacking up?
    VN calais 91
    Aug 2005
    Default help me with probs on superlow and jacking up?
    i just put in superlows all round, and now i have the problem where if i jack it up, the wheel doesn't rise up until you jack it up really high
    i guess i need shortened shocks, but i heard you only need shortened shocks for ultra lows, not super
    also, the springs fall out when i jack it up, which could be an issue in an emergency
    any ideas aside from new shocks?
    also, what is this part? its connected to nohting
    and are these bushes ###ed?
    THANKS!
    '00 WH V6
    Dec 2005
    hakhawk's Avatar
    hakhawk is online now smooth moderator
    BMW E21 320i, E36 318IS coupe
    Jan 2005
    just get the monroe shocks for cars with fe2 suspension. i have them in mine, with ultras and the springs dont fall out
    the part that "connects to nothing" is your bump stops, you need them, so the axle doesnt bash the chassis.
    yep, those bushes are stuffed, theyre mainly there to keep the spring from moving around and scraping the chassis making rotten noises and wearing the metal away.
    VN calais 91
    Aug 2005
    thanks for the quick replies
    will check out some new bushes, as i have been hearing clunks and thunks while turning and coming to stops
    probabbly the bushes
    will check out new shocks, but i was led to believe only ultra lows needed shortned shocks
    wrong info?
    hakhawk's Avatar
    Jan 2005
    definately wrong info. lows you can get away without short shocks, but superlows and lower, generally need shorter shocks.
    the fact that you yourself can see the springs fall out when its jacked up tells you that you need short shocks.
    1991_Vn2nV's Avatar
    91 VN Berlina & 03 VY Berlina
    Mar 2006
    Gumeracha, Adelaide Hills
    Quote Originally Posted by timmy_tam View Post
    wrong info?
    King Springs reccomend shortened shocks be fitted with even Low Springs, let alone superlows and lower.
    padrickz88's Avatar
    padrickz88 is offline Rick =]
    VN V6, nothing special
    Dec 2005
    sunshine, melbourne
    how much would them bushes cost? i think the ones on my rear end need replacing.....
  1. Jacking up lowered vs
    By westoz in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 17-11-2006, 02:49 PM
  2. Jacking up car and using ramps
    By stew_38 in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 18-10-2006, 11:00 PM
  3. Jacking points / stands on a VS
    By futronix in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 15-04-2006, 09:44 AM
  4. Jacking
    By TigerVX in forum General
    Last Post: 28-12-2005, 04:35 PM
  5. Jacking up VT
    By enfz in forum General
    Last Post: 27-11-2004, 08:23 PM
