Page 1 of 5 12345 LastLast
Results 1 to 25 of 107
Thread: Still not starting
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Angry Still not starting
    Hey guys, first up, no stupidity im looking for help here im stumped!
    it runs on creamtops and stock tune with 1 bar! dangerous after boost
    ok so so histroy on the car
    its got a
    t04E turbo
    570cc injectors (55lb/h)
    2 bar map sensor
    walbro 255LPH fuel pump (500-600hp)
    a 1 year old ecu
    1 year old tripple coil pack
    1 month old leads
    5 month old plugs
    1 year old CAS
    now ok, last time i had this car running was last week, just installed 570cc injectors and it started up fine on my 2 bar tune, coulda run better but it was running... now i had LITTLE fuel left, ran it dry on the way to the fuel station
    went and got new petrol, filled her up and she cranked but wouldnt start,
    over the next 2 weeks i replaced fuel pump thinking i fried it and i wanted to upgrade it anyway, it started after installing pump, not running well
    then next day same tune wouldnt start???
    anyway cars sitting in my driveway with creamtop injectors back in, 1 bar map sensor (they run off a stock tune) and it still dosnt start..... this indicates to me its not tune related...
    heres my list of things i thought it might be
    ECU
    FUEL FILTER
    OIL FILTER
    TUNE
    CRAP FUEL
    INJECTORS
    REGULATOR
    FUEL REG
    NO SPARK?
    COIL PACK GROUNDING
    so far, ive tested
    ECU > NOT ECU (tested a spare one)
    TUNE > NOT TUNE
    INJECTORS > NOT INJECTORS
    COIL PACK GROUNDING (despite my coils are mounted on my thermo fan, i have 3 grounds on them, 2 to the chassis and 1 directly to the neg battery terminal)
    no engine lights appear
    so what does it do?
    when you crank it fires maybe 1 out of 6, and its enough for it to help the crank through till the next one.... ive had it started on 1 or 2 before, could barely hear the car was started (2 bar with bigger injectors)
    ive checked leads for fouling ( a big issue with the heat being pumped out by the turbo ) found nothing
    money is not a issue, i could give RACV road side assistance a call, if all else fails, helps to have another mechanic to look at it, he'll probbly look at me and laugh "lol turbo"
    if i can fix this issue the car should be up and running for good
    88GreenVN's Avatar
    88 Green VN Wagon 389,000kms
    Jun 2006
    Deep South - VN Country
    Maybe check the CAS - 1 year old can mean dead CAS. Are the injectors getting power? You did say almost starting. so is it pumping out fuel at the rails?
    and 3 Dangerous non ABS VN's
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    pumping LOTS OF FUEL out the fuel rails, not %100 sure if injectors are making mist.... tommorrow ill unbolt the fuel rail and crank it to see if we can make a mist of petrol...
    i havnt got a fuel pressure gauge onto the line yet, but from squeazing it it feels like it has LOTS OF PRESSURE like round 40psi, feels as tough as a tyre
    CAS would stop it from cranking all together, it still cranks and tries to ignite
    i can smell petrol, after cranking, (probbly from the zorst leak) soo i know shes pumpin the juice.....
    some aditional info, i did get it started after running outta fuel, ran ok..... i got it started my removing memcal and cranking it till it fired 2-3 and died, then reinserted memcal and started i drove it a bit... felt MASSIVELY underpowered especially under boost i turned around and took her home instantly
    any other idea's?
    88GreenVN's Avatar
    Jun 2006
    When you say core pack are you including the DFI unit?
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    i upgraded it to a VN s2 tripple coil system (can replace coils individually, brought it brand spankin new)
    88GreenVN's Avatar
    Jun 2006
    HMMM got fuel, got compression - so its gota be electrical. I'd go over the the connectivity of the injectors and DFI. You dont have a calais security thingo do you?
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    my calais alarm is disabled, and if it was on it wouldnt crank, injectors are connected properly,
    compression isnt a definate but i replaced headgaskets 2 weeks ago with ACL race series headgaskets... i can do a compression test if need be... but i dont think thats it
    injector connectors are fine... ill rip fuel rail out tommorrow
    greenfoam said to test sparks which ill do in a second (see if it arcs)
    Boonz's Avatar
    Boonz is offline the holden mechanic
    green 355 VG ute , silver vx s pac L67
    Jul 2005
    berri, south australia
    may sound dumb but did you hook up the pressure line or the return line to the regulator ? or does it only go on one way
    88GreenVN's Avatar
    Jun 2006
    Thats next slip a plug into one of the leads and see if you have good spark.
    pow3rslave's Avatar
    pow3rslave is offline DoNothing Member
    VP 5.0L
    Oct 2005
    eastern subs, vic
    if you ran it fully dry, could it have sucked up all the stank crud at the bottom of your tank? could have blocked lines or injectors.
    VN_Luke's Avatar
    VN_Luke is offline ƃuoɹʍ ʇsnɾ sı sıɥʇ
    VT, RB30EST VN
    Mar 2005
    spark plugs = fowled from running massively rich...
    remove spark plugs.... clean with wire brush (or just buy new ones)... re-insert plugs, start car.
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    i will try that luke!
    also got a compression test happening tommorrow to rule it out
    shes sparking from the leads into a plug
    thats a negative on blocked plugs,
    maybe blocked fuel pressure but at bare least it should start up, next stop check plugs and for the funny tasting mist (fire injectors into air)
    88GreenVN's Avatar
    Jun 2006
    [QUOTE=PaRaDoX616;565775]
    shes sparking from the leads into a plug[QUOTE]
    Thats a good sign at least - but dont fix your problem
    Back to the start - What did you do before the no start, was it changing the injectors?
    ha just read the first post and she ran out of fuel.
    When you replaced the fuel pump did you get all the wires connectd OK have you checked your work in that area?
    vt1538's Avatar
    vt1538 is offline 455rwhp LS3
    VY SS S2 11.284@125mph
    Sep 2005
    The Dead Centre
    So are you running the stock tune with the original 1 bar sensor or the modified tune ?
  15. #15
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    im sure i wired it correctly, shes pumping fuel....
    as she sits on the street it has
    creamtop injectors (close to stock, will run on a standard APNX tune fine)
    1 bar map sensor
    stock tune..
    no reason it shouldnt start (it usually works on this config)
    compression test + pug/lead test will happen when i get some more spare time off work + study (exams this week, havnt had the most spare time)
  16. #16
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    i just had a crazy thought, back when i blew the headgaskets i broke the detonation sensor wire and plastic clip, now i soldiered it back together but what if i stuffed it????
    ill grab one from the wreckers and test it out.... could be a theory!
  17. #17
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
  18. #18
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    Do you know anyone with some noid lights or an LED test light to plug into the injector harness? Just to make sure there is a regular signal. Also check all your fuses & relays.
  19. #19
    vt1538's Avatar
    Sep 2005
    The Dead Centre
  20. #20
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    noooooo, what im getting at is,
    its connected (wired) howevere detecting false detonation and retarding the engine not allowing it to start.... thats my theory,
    therefore also not giving a engine light
    its been running since i changed the headgaskets but it would explain the on/off working
  21. #21
    vt1538's Avatar
    Sep 2005
    The Dead Centre
    The computer is not doing anything to the spark until certain criteria are met. That will not be the issue.
  22. #22
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    ok well, im not going to get time to test it untill this atleast friday sooo ill get back to you
  23. #23
    VC Twin Turbo, VN Turbo, VY Storm
    Oct 2006
    Quote Originally Posted by VP_Luke View Post
    It has to be this i went through 12 set of plugs when i first got my turbo VC running with the micro tech every time i went to put it on the dyno i found something wrong or something i was not happy with and just from moving it in and out of the work shop is would just stall and never start again unless i put new plugs in.
  24. #24
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    bout due for a plug change anyway should i stay 1.5mm gap or go to 1.0mm? or other
    i just noticed a error in my previous post "thats a negative on blocked plugs," i ment blocked injectors
    havnt even looked at plugs YET, i will when i get spare time
  25. #25
    Aug 2004
    buy super v6 plugs they are factory gapped down
  1. Help Please Starting VS
    By obsessed in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 23-11-2007, 07:06 PM
  2. Just Starting out
    By Thomas1 in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 06-10-2006, 06:26 PM
  3. self starting car
    By SLugg in forum VZ Holden Commodore (2004 - 2006)
    Last Post: 19-06-2006, 10:42 PM
  4. starting
    By ab56452001 in forum Electrical Wiring / Questions
    Last Post: 04-01-2006, 10:04 PM
  5. no starting sometimes
    By phoenix_blue in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 30-06-2005, 01:33 PM
