Results 1 to 8 of 8
Thread: Strut caps removeable?
    AirStrike's Avatar
    AirStrike is offline Site Administrator
    2009 G6ET
    Jun 2003
    Default Strut caps removeable?
    Hey all just wanting to know if the plastic caps on top of the rubber strut tops is removable at all? My shocks are adjustable, but the adjuster it at the top which makes me think they are removable.
    Selling FG G6E Turbo and buying a N/A Supra
    Not_An_Abba_Fan's Avatar
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    The plastic cap that you have to take off to undo the nut that holds the strut to the bearing plate? Just use a screw driver and it pops off.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    Quote Originally Posted by Not_An_Abba_Fan View Post
    Oops, no arrow.
    Thats the one.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    Yep, they pop right off. If your struts are adjustable, isn't there a valve on the base that you rotate or is yours done by turning the shaft? By adjustable I take it that the damping rate and not the ride height is the adjustable bit.
    AirStrike's Avatar
    2009 G6ET
    Jun 2003
    They're bump/rebound adjustable, not hight (thats coil overs). The KYB shocks work by turning the shaft in the top for VN-VS. VT onwards has the knob at the base.
    Going to have to firm them up as im looking at lowering it some more, and also to adjust to the softest setting at the drags to help weight transfer.
    HSV Senator VTII
    Aug 2006
    Bunbury, WA
    I have done a few adjustables but they were on VU utes so the valve was on the bottom.
  1. Caps and fuses
    By SthEastCustoms in forum Car Audio
    Last Post: 05-01-2007, 05:42 PM
  2. Wheel Caps / Centre Caps
    By zandahar in forum VT - VX Holden Commodore (1997 - 2002)
    Last Post: 02-03-2006, 01:56 PM
  3. Billet Strut Caps
    By death-from-above in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 11-06-2005, 10:08 PM
  4. Fuel caps
    By thomasr in forum V6 Development And Modification
    Last Post: 23-03-2005, 07:09 PM
  5. stolen hub caps..
    By Righty in forum General
    Last Post: 25-02-2005, 09:06 PM
