Results 1 to 12 of 12
Thread: Help! My VN is dying
    Dec 2005
    Default Help! My VN is dying
    Hi guys,
    There is a problem with my 1989 vn calais and is is really starting to scare me.
    Last week while i was driving my car it all of a sudden started to be really rough and jerky. Now it happens all the time. It is not smooth at all and you can hear it when you rev that it is all broken up. Sometimes it gets so bad that the whole car just shudders violently. The more i rev the worse it is. I recenty changed the fuel pump, filter and injectors so it couldnt be those.
    Does anyone know what it could be? If anyone wants me to be more specific just ask. Thankyou.
    VN CALAIS/VT executive
    Sep 2005
    Quote Originally Posted by down_with_the_system View Post
    Hi guys,
    is it popping /back firing? you have the correct calibrated injectors.
    i'd be looking at the spark/ignition before thinking of a more serious cause you have described
    Dec 2005
    nah it isnt back firing. The best way to decribe it is the engine isnt getting enough fuel so it is choking trying to stay alive. Im not saying thats the problem but its just how it feels.
    Sep 2005
    yeah could well be...but why is the question as you have asked...OK you have put in new fuel pump,were the injectors your original ones or, reconditioned ones or even just second hand ones, and are they for that motor....sounds silly i know,but has happened,obviously fuel filter has been put on the right way.can you hear the fuel pump whirring when you first turn the ignition on,just before firing it up?
    Dec 2005
    I can hear the fuel pump when i turn the accesories on, before i start the engine. And the injectors etc were all put in buy a licenced mechanic, so i doubt they are wrong.
    Sep 2005
    OK....so he would of checked fuel pressure,well he should of done,so if he did his job correctly,the fuel side of things should be all good,unless,because of new/reconditioned injectors,being restored to perfect working condition/specifications it has put a strain on the untouched,aged fuel regulator....so i would be moving onto spark if all the fuel side of things have been checked and sorted
    2004 Black Vz R8 HSV Clubsport 297kw Gen IV M6
    Apr 2006
    South australia , Adelaide
    Could also Be CAS, or even the gear box, i know when my gear box was playing up it sounded liek what you have described.
    =Brock=
    My Ride
    2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
    jules's Avatar
    jules is offline we like the bun
    pimpin
    Dec 2003
    ignition system is a known issue. open up the coils and check the resin in the DFI module below. if it's a bit molten looking then it's toast. it could still be toast anyway.
    another possibility is the ECU, mine went. you need to get that tested to tell for sure.
    Claudy's Avatar
    Claudy is offline French Com
    Manual Gen3 VT SS + V6 VT manual turbo
    May 2006
    Perth, Two Rocks
    Have you checked all your leads? Happened to me when one of mine was shorting out on the extractor whcih melted it...
    Gen3 6spd Manual VT SS
    VT V6 Manual turbo
    PaRaDoX's Avatar
    PaRaDoX is offline boosted!
    Forester GT, VT S Supercharged, Supra Turbo
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by samuels View Post
    only way you can calibrate injectors is to edit the binary file in the ecu, its not possible manually.... its injected remember?
    sounds like you have a coil pack issue there son..
    check your coil pack ground (braided line that goes to the chassis near the airbox)
    definatly a spark issue not fuel system
    VnExecutive
    Mar 2007
    Cranbourne
    PaRaDoX's Avatar
    Apr 2005
    Melbourne, Victoria
    Quote Originally Posted by Claudy View Post
    hahahahahahahahahaha..... i know your pain, turbo's melt things!
    are you down on power? or just making funny nosies??? or both!
    airfilters definatly worth checking out
    are you using original coils???? the Series 1 VN v6 used the single moduel, the series 2 used the tripple coil system (i have one fitted to mine)
    its common for the DFI modeul to go, considering its bolted to the engine the soldier joints just dont hold up with the vibrations over the years (borrow someones coil packs to test)
    does it just shake or can you feel the engine playing funny buggers?
    they get to this age and the original engine mounts are as flat as road kill and have big cracks in them with leaking fluid...
  1. Help! Is my DFI module dying?
    By michaelw in forum VN - VP Holden Commodore (1988 - 1993)
    Last Post: 20-09-2007, 02:36 PM
  2. My Car Is Dying
    By outlaw in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 27-01-2007, 10:03 PM
  3. Dying VR?
    By pineforest in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 10-12-2006, 11:19 PM
  4. Synchros dying?
    By ozzietj in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 28-05-2006, 01:49 PM
  5. my VS is dying help
    By VSAccCom in forum VR - VS Holden Commodore (1993 - 1997)
    Last Post: 26-09-2005, 08:11 PM
