Hey everyone im getting a service done this week and was just wondering what it is they actually do? change coolant/oil/brake fluid...wouldnt it be chaper to do this yourself?? or am i wrong?
=Brock=My Ride
2004 Phantom Black Vz R8 Hsv Clubsport 297kw 6L Gen IV M6-6 speed, Full black leather -
what is it they actually do? just replace fluids, cause if thats all they do then em and my dad can do all that crap :S
=Brock=My Ride
once again it's all on the level of service and pricing of the service,basic service is just oil,oil filter,fuel filter,plugs,check all fluid levels,clean or replace air filter,inspect brakes,tyres and basic tune and some crowds put injector cleaner in fuel tank...the price range for this service is $80.00-$120.00
if you aren't using GMH service centre,and the mechanical service that you will be taking your car to is reputable,they adhere to GMH's service notices,I.E most cars reccomended coolant change is every 2 years,gearbox and diff oils are about the same,as is the brake fluid,so if none of this has been done to your car in the last 2-3 years the level of service your car will require, will be quite expensive up to $350.00 +( including labour)
i forgot to add,depending on the mechanic,they would stick the lap top in,and just see whats going on with your tune,8 times out of ten you will get a crowd saying that they picked something up in diagnostics,in the hope of squeezing more money out of you.....so if you can get a second opinion for nothing,it pays to do so.although this kind of set up is pretty well regulated now,ripping people off,it's been on all the current affair shows...
ok then thanks for your input samuals i think ill just get the service done then, as i still have that crap whistling from removing my throttle body (took out bellmouth), i was gonna get them to fix it while it was there.
=Brock=My Ride
Get ur self a set of Plugs,5 Litres of Penrite HPR 10 or HPR 15 depends on km of engine,Oil Filter, GMH Coolant to suit Vt Heads,leads if need be - check brakes,trans fluids for leaks or around the power steering pump.
other things to consider,wheel alignment,tie rods,sterring rack,uni joints,ball joints,brakes,suspension,trans service,diff service and so forth
Cheers.![]()
* RVN 355 *
coolant and most fluid changes can be totally done at home (or a mates place to save yourself cleaning up after)
most of the instructions you'll need are in howto
coolant/thermostat
fuel filter
oil and filter change
most of these go into awesome detail and have product and tool listings, it's dirt cheap and a good way to learn about how to do trickier stuff later.
Refrain from naming and shaming businesses in here, if you wish to slander a company, do it in private.
Beau Duke: Man, I'm never gonna get outta this car again. I'm gonna live in it, I'm gonna eat in it and I'm gonna make sweet love to it!
Luke Duke: You mean you're gonna make sweet love IN it.
Beau Duke: Oh no, I'm gonna have sex with it.
please tell me which company(ies) i have named, slandered or shamed,as none have been mentioned,was a passing comment,or aren't you allowed to do that by law? i did however state that most reputable mechanics adhere to GMH's service notices,i did mention GMH service centrebut you show me where i have name called them,slandered or shamed them.....
yes, I used Penrite HPR 10 but the engine is funny and not stable while waiting for the traffic light. should I just change back to castrol?
Off the topic a bit, servicing the diff, I have checked Gregories and there is no service interval, I have never changed the oil in it and the car is 220k.
do it yourself its cheaper and you know that you have changed the parts.
to drain, remove the bolt on the bottom in the centre of the cover plate, while it is draining remove the plug halfway up the cover plate, once it has drained most of the oil, flush a little bit of your new fluid through the filler hole and let it drain,
to fill, replace the plug at the bottom of the diff, and start filling at the top, once the oil starts coming out the filler hole allow it to stabilize and replace the plug
should take around 1.7 litre of oil
