LIFES A GARDEN, DIG IT..lol
yer its safe if your careful. is the top of the thread still there?
the thread of what the bolt??
hang on i didnt see the pic properly . remove the shim plate and use a set of vice grips on it
give the bolt a lil tap to loosen the thread
shim plate??? please explain lol
on the vn series one they had a shim behind the water pump to the timing cover.
hmm ill have a look..
drilling it out is fine as long as u dont go in on the piss. but if the thread is rooted u can get an insert where u drill a larger hole and tap it then insert a thread insert to make it the same threah diameter, it will be an m10 thread on ya bolt. not trying to make out ya dumb just a lil help :P
i took off the plate thing and i could get to aprox 3 mm of the old bolt and i tried to used vice grips and it didnt work its rusted on good so im gonna try and get away with out driling it n use some gasket goo lol well ill c and if i get away wit out drilling it out it will be a bounus i guess.. other wise ill have to tow her into work n do it..
spray some CRC in around the rusted thread, and wait an hour or so, then try ur vice grips again.. or yea drill and tap
