will a electric mirror switch from a vr/vs work in a vp commodore? there switches are much nicer.
vr is the same square switch as the vp, vs is the round one. i bought a vp switch for my vp, but it was just as dodgy as the old one, so i gave it to dad, but his was a different plug or different pins and amount of wires or something.(his is a vr)
id assume using the same plug and matching the wires, the vs one should work fine.
these switches with the wires there is nothing different about them.
the only thing I saw when changing it over was the handle on the door. if you use the one that comes with the VS switch it fits perfect. but the color might be a bit different.. I just just my VP handle to fit the new switch. it fits pretty neat and works perfect..
Just make sure you check all the sizes and the colors but it is a doable item.
I've Got Papers To Prove I'm Sane.
Can You Produce Some Too ???
Madhouse_Dave
im about to install electric mirrors into my wagon, i got all my stuff of a vs so i got the good switchif you like i can take a photo of the conector, but its square with 2 rounded edges, with 7 used pins. you could just cut and solder your old plug onto the new switch if it doesnt work..
